WTB : Early (1971) Struts (Outer Part) ***SET PURCHASED***, Need Early Struts |
Toolboy32 |
Jul 6 2018, 06:54 PM
Newbie Group: Members Posts: 2 Joined: 30-June 18 From: Michigan Member No.: 22,275 Region Association: Upper MidWest |
Looking for parts
Found the attached diagram on AutoAtlanta They need to be the early versions, unless you experienced guys know that the newer ones work fine on a '71. They do not have to be clean, just not damaged in any way. I have become quite adept at cleaning off rust and rehabilitating parts. (but clean would be nice) |
Toolboy32 |
Jul 7 2018, 06:55 AM
I have located a set.
When I was discussing with the seller, I mentioned that I was worried that when they swapped in the 2.0 engine from a'76 that they may have swapped some other stuff out. He helped me to determine that they are later versions mounted on my '71 body. Luckily the seller had both styles. I appreciate all the help from KevinW from MN! Saved me a giant headache. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:15 PM |
