Annoying grinding noise after new pads |
andreic |
Jul 6 2018, 04:36 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
I installed new brake calipers and pads in the front on my 1.7L 914 (1972) after I discovered that one of the calipers was sticking. The calipers were high quality rebuilds from PMB.
Now I have this super annoying grinding noise whenever the car is moving. The noise is like something is grinding against the pads. It is there no matter if I press on the brake (hard or soft or at all), but it gets a bit louder if I step on the brake. I suspect that the new pads are a bit wider than the old ones. When looking at my disks again today I noticed that there is some surface rust on them, about the first 1/4" both from the outside edge and from the inside. I know I should have had my brake disks turned when I changed the calipers, but did not do it. My question is: will this annoying noise go away with a bit more driving, after the pads wear out a bit, or do I need to remove the calipers again, take the brake disks off to be turned, and reinstall everything? Sorry for the low quality pic... |
Chris914n6 |
Jul 7 2018, 11:47 AM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I once picked up an early 911 that just had brakes done, by a reputable shop. Grinding the whole way home. Found one of the pads was put in backwards....
porschetub |
Jul 7 2018, 05:08 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I once picked up an early 911 that just had brakes done, by a reputable shop. Grinding the whole way home. Found one of the pads was put in backwards.... (IMG:style_emoticons/default/WTF.gif) ha ha did that once but only had myself to blame ,my wife needed her car in a hurry and I rushed the job . |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:54 AM |
