Diagnosing D-Jet Problem...solution & update, All of a sudden...loss of power... |
MikeInMunich |
Jul 6 2018, 08:13 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich gentlemen! (IMG:style_emoticons/default/bye1.gif)
It started with a thought and no wood to knock on, seriously! (IMG:style_emoticons/default/mad.gif) I was driving around Munich about 6 weeks ago and thought to myself, this car is running perfectly and needs nothing. What could go wrong? Then literally, less than a few minutes after that, it started. A light hesitation in the lower RPM range. Seemed like the car was choking a bit, or missing on once cylinder. I was at a D-Jet workshop last year with Dr. D-Jet. See https://oldtimer.tips/de/ Volker is a great guy and knows as much about this system as anybody. He tested the vacuum on my MPS last year and informed me that it was "borderline". So that was the main culprit. I took it out, sent it to him and this year it was indeed worse and thus the main culprit. Volker disassembled it and replaced the copper diaphram. Now it's tight like new. Some may be surprised that this is possible and / or where he got a new diaphram from. He had them manufactured or perhaps, I'm not sure, manufactured them himself. PM me if you want / need one and I'll send you his email address. So, with my restored MPS I hooked it up and, low and behold, the problem was quite the same, only about 10x worse! (IMG:style_emoticons/default/hissyfit.gif) Now, with the car immobile and Volker hundreds of km away, I'm practically on my own, with his and your advice, to try to track down the real problem. Volker thinks that because the MPS was operating sub-optimally previous to my purchase of the car that the mechanic or the P.O. had compensated elsewhere to get the car to run properly and that now that the MPS is sending a different signal to the CPU, things are off. More info: Just before the problem started my milage was really bad The CPU is the correct one for my MPS and working according to specs. Volker tested it. Engine has about 5,000 miles on it. Was rebuilt and running GREAT. Fuel pressure was set at 29 psi only about a year ago. I reckon it could have hardly changed on its own since then. (IMG:style_emoticons/default/idea.gif) The engine was originally a 1,7 but is now 2liters with a “proper FI performance Webcam” (as stated by the mech ic who rebuilt the engine) No adjustments were made to the FI to get it to run properly. It was running excellentwith a virtually perfect idle when warm and just slightly rough for the first 3 Miles or so. TPS plate and air temp sensor are new. What do y'all reckon could be the culprit? What should I be testing? I'm taking it to a place to tell them what to test, including: Fuel Pressure Plugs Compression CO value TPS setting Timing & dwell search for Vacuum leaks grounds Valve adjustment Fuel filter Relais Injectors... What else should I have them look for? Thanks for your input! With best regards from what was just ranked The Most Livable City in the World by Monocle Magazine, Mike in Munich |
nordfisch |
Jul 8 2018, 07:07 PM
Member Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
Hi Mike <and all others interested in this topic>,
you can be absolutely sure the MPS and the ECU you got from Dr-DJet are fully functional and correctly adjusted. The new diaphragms he uses are NOS types he bought directly from the former producer and he adjusts the MPSs as fine as even possible using his own equipment and value-tables more exactly than the OEM can do this today. In addition, he uses the original equipment and data the OEM used and uses for this task. He owns this very rare equipment and tools and is a perfectionist. He doesn't open the seal of the MPS to do this but reopens it some more times if neccessary to adjust it from the inside. You will not get the parts back from him in perfect optical condition - he is a hobbyist and doesn't waste time doing things others can do - but does make a perfect technical service. In addition, he gave you a second MPS and a second ECU for testing, both with the correct part #. Yes - I saw and registrated you in Erlangen / Nürnberg only two weeks ago, but we didn't talk to each other, because you were in a hurry and up and away before I could talk to you. Maybe you saw my blue Opel Diplomat... We had email-contact some months ago and I remember some of the problems you had with your car... ---- Please do exactly what Dave says. Do it in full. Don't leave anything out. Add opening the D-Jet main-relay carefully to the to-do-list. Maybe it has become weak as it happened once at my own car. Maybe you see brittled contacts... And don't forget: Do all the testing and measuring at the ECU-connector. The wiring harness and ground connections are so often defective. One missing or bad contact can be the reason for all of your problems. Don't forget the grounds... dont only check them visual or by multimeter, but pull them off at the engine or screw them off at the relais board and elsewhere, clean them and the ground-point, too. I saw your original ECU laying on the table in Erlangen, it was covered with underbody protection material. Maybe the relais-board-area looks similar. Paint = no electrical connection! Regards Norbert |
Lo-Fi Version | Time is now: 10th June 2024 - 10:33 AM |
