| motorvated |
Jul 9 2018, 08:51 AM
Member ![]() ![]() Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Is it possible to determine what cam is inside the 2.0 liter four cylinder motor I just purchased, without splitting the cases. Can a dial gauge on the rocker arms and degree wheel on the flywheel be used to measure the cam lift and profile. Are any cam markings visible without splitting the cases. The engine was last run with carbs, but no history of whether or not the cam was ever changed. I'd prefer not to disturb the bottom end if possible. Tried a search, but couldn't find anything.
| Dave_Darling |
Jul 9 2018, 04:58 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,356 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
And of course you can put a dial indicator on a pushrod or a lifter (if you can get access) or a rocker arm and use a degree wheel on the crank. It can be tough to match those measurements up with published info, though.
--DD |
motorvated Identify Cam Without Splitting Cases Jul 9 2018, 08:51 AM
injunmort I have been told the easiest way is to remove oil ... Jul 9 2018, 09:24 AM
The Cabinetmaker Exactly like Mort said Jul 9 2018, 11:04 AM
Mark Henry If it's bolted (aftermarket) most cam grinders... Jul 9 2018, 11:33 AM
motorvated
And of course you can put a dial indicator on a p... Aug 24 2019, 12:21 PM
JFJ914
[quote name='Dave_Darling' post='2627592' date='J... Aug 24 2019, 12:51 PM
motorvated
[quote name='Dave_Darling' post='2627592' date='... Aug 24 2019, 01:06 PM
Superhawk996 Nope. 2.0L (stock) is more like 95HP. But a 10H... Aug 24 2019, 05:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd August 2026 - 12:42 AM |
