> Help needed... Regulator..? +
Dengo77
post Jul 11 2018, 12:07 PM
Region Association: Europe
Hello Porsche 914 fans
I needed some help, this regulator which is marked on the picture (red)... It is broken (rusted up) and therefor the engine is not happy.
What is going on with this part and does anyone know where it can be bought..?
Another issue is that several tubes are blocked, marked 2 with (Yellow). Hope that they are clear on the picture.
I bought the car in US some year ago and this year the plan was to fix it up… But..
Thanks and look forward to hear from one of you…
Dennis
jcd914
post Jul 11 2018, 12:49 PM
The red circle is around the check valve for the Air Injection manifold, which is a Smog system require in California (maybe other states) in 1975 & 76. You can remove the complete manifold but you will need to block off the air noozles or ports in the heads or else you will have 4 large exhaust leaks.
I can't tell what is in the yellow circle but it is the general area for the Aux Air valve which provides more air to the engine when it is first started cold. You can take it out and clean it with carb cleaner or soak with wd-40 or other solvent to get it to free up, sometimes it works.
Good luck
Jim
- Lo-Fi Version Time is now: 16th July 2025 - 06:09 PM
