Dengo77 |
Newbie ![]() Group: Members Posts: 2 Joined: 11-July 18 From: Denmark Member No.: 22,303 Region Association: Europe ![]() |
Hello Porsche 914 fans
I needed some help, this regulator which is marked on the picture (red)... It is broken (rusted up) and therefor the engine is not happy. What is going on with this part and does anyone know where it can be bought..? Another issue is that several tubes are blocked, marked 2 with (Yellow). Hope that they are clear on the picture. I bought the car in US some year ago and this year the plan was to fix it up… But.. Thanks and look forward to hear from one of you… Dennis Attached thumbnail(s) ![]() |
Dengo77 |
Thanks Jim...
Will try to find a new check valve.. Dennis |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
I would remove the tubing for the air injection and as previously stated just screw caps on to the air injectors. Will clean up the engine compartment, the only thing that tubing did was when connected to an operating air pump, dilute the exhaust with fresh air, a lot of gizmo for not much result
All 50 state 2.0 75 76 914 models had this assembly installed, and it is not worth trying to keep up unless you have a concours car or a 1976 you have in California You can find the screw on caps at a plumbing supply place Thanks Jim... Will try to find a new check valve.. Dennis |
Lo-Fi Version | Time is now: 16th July 2025 - 06:16 PM |
