Can't Turn the Heater Off, And smells like exhaust... |
Jackba |
Jul 16 2018, 08:57 AM
Newbie Group: Members Posts: 40 Joined: 13-July 18 From: Sacramento Member No.: 22,308 Region Association: Northern California |
I hadn't driven my 74 2.0 for several months due to work on another project. Took it out yesterday and it felt like the heater was on full blast, plus it smelled like exhaust in the cabin. Top was on ant it was a hot day but I've never experienced that sensation before. The heater controls were in the off position.
When I restored my car a few years ago I pressure checked the heater boxes an they were good. Any ideas? Thanks, Jack |
r_towle |
Jul 18 2018, 06:27 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Until you really want to fix it, which may take a while...
Remove the two rubber hoses that connect the flappers to the chassis tubes. Grab two standard spray paint (rattle can) covers and put them over the tubes that lead into the chassis. The right ones fit like a glove. Use a couple of large screw clamps that held the rubber tubes in place. Now you will have time to remove the flappers and see what is going on while you can safely drive the car. |
Jackba |
Jul 18 2018, 02:23 PM
Until you really want to fix it, which may take a while... Remove the two rubber hoses that connect the flappers to the chassis tubes. Grab two standard spray paint (rattle can) covers and put them over the tubes that lead into the chassis. The right ones fit like a glove. Use a couple of large screw clamps that held the rubber tubes in place. Now you will have time to remove the flappers and see what is going on while you can safely drive the car. I discovered yesterday that there was sufficient tension on the heater box cables to allow heat to get into the cabin. I put slack in the cables so the flaps could close. As an extra measure, I removed the hoses. I'm going to be using the car for some events and it's certainly hot enough outside where I will not need a heater. Your suggestion to cap the firewall tubes is a great one. Thank You! Over the winter I'll pull the heat exchangers and do another pressure check. Thanks everybody for all the help. Jack |
Lo-Fi Version | Time is now: 8th June 2024 - 04:49 AM |
