Size of Butyl Tape for Winshield/Rear Glass Install, questions on what adhesive to use on glass |
porsche914_73 |
Jul 18 2018, 07:32 PM
Fred Larracuente Group: Members Posts: 12 Joined: 4-November 06 From: Guaynabo, Puerto Rico USA Member No.: 7,149 Region Association: South East States |
Hi Guys!
Questions and more questions about windshield/rear glass sealants to use on my rebuild: 1. What is the correct size of butyl tape that I should use when reinstalling the windshield and rear glass? 2. Any reasons why I should use modern windshield sealant instead of butyl tape like the factory did? 3. I'm going for a dechromed look on my rebuild (L96B Alaska Blue with dechrome and roll bar vinyl delete, gloss black painted bumbers, rockers, 2.0 Fuchs). Have anybody had any experience with the windshield rubber moulding kit that 914rubber.com sells? Windshield Chrome Replacement Rubber on 914Rubber.com I believe the butyl tape it should be 10mm as used in a kit on 914rubber.com for the rear glass but want to make sure that is the size. Last time I got a windshield installed, the installer used the black goo adhesive that comes in a tube but excess can be seen on the edge past the chrome moulding so also affecting the height glass and the moulding fitment. Have no doubt that it will hold but maybe he just used too much. What adhesive do you guys use/prefer? There's some butyl tape/rope/cord for sale on eBay (1/4, 3/16 and 5/16 sizes) and it states is suitable for windshields but open to your opinion. 5/16 Butyl tape on Ebay Thanks for your comments, |
76-914 |
Jul 19 2018, 12:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I’ve used 3/8” once. I needed to really work the windshield in the hot sun in order to get it low enough for the aluminum trim to click onto the plastic clips. As mentioned above; test fit it first and see if the gap is uniform. If not then I’d use 3/8” again. Otherwise 8mm works fine for me. Just be sure you can see that the butyl makes contact all the way around. It will be obvious. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 6th June 2024 - 05:42 PM |
