How can I tell if these 96mm Arias Pistons are for 1.7/1.8 or 2.0 |
jcd914 |
Apr 13 2008, 12:19 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I am doing some spring cleaning (IMG:style_emoticons/default/sad.gif) and I am going to sell off some of the excess I have but before I can to that I need know what I have so I can decide if I should keep or sell. About a decade ago I bought a bunch of stuff for a Porsche shop having a yard sale. It was a pile of boxes that they did not want to put back away.
In one of these boxes was a set of new 96mm pistons with bored out 94mm mahle cylinders. I don't know if these are meant to go on a 1.7/1.8 bottom end or if they are for a 2.0 bottom end. I could install one on a partially assembled bottom end but I was hoping someone might know a way to measure and determine. These are Arias pistons with a dome on them. I don't think I have come across any other domed pistons for a 914 and I don't know anything about Arias. I have not pulled any of the pistons out of the cylinders yet but cylinder wall look nice and the pistons will move if I push. Any info would help me. Thanks Jim |
914werke |
Jul 20 2018, 10:21 AM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Typically a visual inspection of the piston will tell you.
if the pin position is much lower than the ring lands it is for the 66mm stroke crank if the pin position is just below the lower ring land it is 71mm |
SirAndy |
Jul 20 2018, 12:08 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Typically a visual inspection of the piston will tell you. if the pin position is much lower than the ring lands it is for the 66mm stroke crank if the pin position is just below the lower ring land it is 71mm This thread is 10 years old ... (IMG:style_emoticons/default/huh.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:36 AM |
