BPGREER |
Member ![]() ![]() Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 ![]() |
OK, I'm once again stumped. My car just won't idle smoothly. It sounds like it's going to die, but then revs itself up a bit, then almost stalls again, then revs again... So, I thought it might be a vac leak. I had already replaced all of the hoses, but found that I had leaks on the air intake runner things, where they connect to the plennum. So, I disassembled everything, replaced those hose-type things, and voila! No more vac leak there. Problem is, still not idling right. It's just as bad now as before. One more thing, I slowly brought up the rpms from the throttle body, to listen, and I think I heard a couple of really quiet backfires. Maybe an exhaust leak? Could this cause a bad idle? Thanks.
Brian |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
How did you set the tps?
Lo-Fi Version | Time is now: 16th June 2024 - 03:15 AM |
