Size of Butyl Tape for Winshield/Rear Glass Install, questions on what adhesive to use on glass |
porsche914_73 |
Jul 18 2018, 07:32 PM
Fred Larracuente Group: Members Posts: 12 Joined: 4-November 06 From: Guaynabo, Puerto Rico USA Member No.: 7,149 Region Association: South East States |
Hi Guys!
Questions and more questions about windshield/rear glass sealants to use on my rebuild: 1. What is the correct size of butyl tape that I should use when reinstalling the windshield and rear glass? 2. Any reasons why I should use modern windshield sealant instead of butyl tape like the factory did? 3. I'm going for a dechromed look on my rebuild (L96B Alaska Blue with dechrome and roll bar vinyl delete, gloss black painted bumbers, rockers, 2.0 Fuchs). Have anybody had any experience with the windshield rubber moulding kit that 914rubber.com sells? Windshield Chrome Replacement Rubber on 914Rubber.com I believe the butyl tape it should be 10mm as used in a kit on 914rubber.com for the rear glass but want to make sure that is the size. Last time I got a windshield installed, the installer used the black goo adhesive that comes in a tube but excess can be seen on the edge past the chrome moulding so also affecting the height glass and the moulding fitment. Have no doubt that it will hold but maybe he just used too much. What adhesive do you guys use/prefer? There's some butyl tape/rope/cord for sale on eBay (1/4, 3/16 and 5/16 sizes) and it states is suitable for windshields but open to your opinion. 5/16 Butyl tape on Ebay Thanks for your comments, |
porsche914_73 |
Jul 18 2018, 09:14 PM
Thanks guys for the input. Another question, butyl on the frame or on the glass? Done plenty of work on cars but have to admit is my first windshield install.
Thanks! |
Coastal6 |
Jul 18 2018, 11:00 PM
Newbie Group: Members Posts: 47 Joined: 15-March 10 From: Florence, OR Member No.: 11,467 Region Association: Pacific Northwest |
Thanks guys for the input. Another question, butyl on the frame or on the glass? Done plenty of work on cars but have to admit is my first windshield install. Thanks! Buytl on the frame. Make sure the frame is clean with alcohol or they even make a special primer that you paint on with a small brush to make the buytl stick better.. Also make sure to install new clips for the windshield trim in the window frame first. Place a couple of tiny rubber blocks the thickness of the windshield and about 1/2 inch long at the bottom of the windshield frame so that when you set the windshield in place it doesn’t creep to the bottom of the frame but stays centered so the gap is the same all the way around the windshield. Do a trial fit before you lay the buytl in place to make sure everything is centered. Otherwise the trim will not snap in and lay flat. Leave the rubber blocks in place and install the trim over them. |
porsche914_73 |
Jul 21 2018, 07:38 AM
Thanks guys for the input. Another question, butyl on the frame or on the glass? Done plenty of work on cars but have to admit is my first windshield install. Thanks! Buytl on the frame. Make sure the frame is clean with alcohol or they even make a special primer that you paint on with a small brush to make the buytl stick better.. Also make sure to install new clips for the windshield trim in the window frame first. Place a couple of tiny rubber blocks the thickness of the windshield and about 1/2 inch long at the bottom of the windshield frame so that when you set the windshield in place it doesn’t creep to the bottom of the frame but stays centered so the gap is the same all the way around the windshield. Do a trial fit before you lay the buytl in place to make sure everything is centered. Otherwise the trim will not snap in and lay flat. Leave the rubber blocks in place and install the trim over them. Awesome tips! Thanks! |
Lo-Fi Version | Time is now: 6th June 2024 - 09:16 PM |
