Why won't my car idle right? |
BPGREER |
Nov 16 2004, 06:36 PM
Member Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 |
OK, I'm once again stumped. My car just won't idle smoothly. It sounds like it's going to die, but then revs itself up a bit, then almost stalls again, then revs again... So, I thought it might be a vac leak. I had already replaced all of the hoses, but found that I had leaks on the air intake runner things, where they connect to the plennum. So, I disassembled everything, replaced those hose-type things, and voila! No more vac leak there. Problem is, still not idling right. It's just as bad now as before. One more thing, I slowly brought up the rpms from the throttle body, to listen, and I think I heard a couple of really quiet backfires. Maybe an exhaust leak? Could this cause a bad idle? Thanks.
Brian |
JohnM |
Nov 16 2004, 09:46 PM
914 enduro driver Group: Members Posts: 179 Joined: 23-July 04 From: San Diego Member No.: 2,387 |
In addition to VSQ's last very good basic tuning advice, check fuel pressure in spec. Often overlooked and assumed correct, if it is off this can make tuning/idle adjust an exasperating experience. If still having problems and can't find a vac leak, how about injector seals?
John |
Lo-Fi Version | Time is now: 16th June 2024 - 08:31 AM |
