BPGREER |
Member ![]() ![]() Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 ![]() |
OK, I'm once again stumped. My car just won't idle smoothly. It sounds like it's going to die, but then revs itself up a bit, then almost stalls again, then revs again... So, I thought it might be a vac leak. I had already replaced all of the hoses, but found that I had leaks on the air intake runner things, where they connect to the plennum. So, I disassembled everything, replaced those hose-type things, and voila! No more vac leak there. Problem is, still not idling right. It's just as bad now as before. One more thing, I slowly brought up the rpms from the throttle body, to listen, and I think I heard a couple of really quiet backfires. Maybe an exhaust leak? Could this cause a bad idle? Thanks.
Brian |
BPGREER |
I set the fuel pressure to 29psi. I took the TPS apart before I set it to check the tracks, and it looked good. The car only has 62xxxmiles on it. Where on the ecu is the adjustment knob? Also, all new injector seals, fuel lines, cap, rotor, wires, plugs, fuel filter, valves recently adjusted (they were right on). Just to give a little background, the car sat in a garage from 1987 until this summer when I bought it in an auction.
Lo-Fi Version | Time is now: 16th June 2024 - 02:23 AM |
