Slight oil leak from screw next to oil filter, Oil leak |
tsvo |
Jul 26 2018, 08:43 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have a 1973 1.7. I noticed a small puddle on my garage floor this morning. I cleaned it up and have not seen any more. I looked under the car and I think it is coming from the small screen next to the oil filter. Can anyone tell me what this is and what I need to fix it? It seems tight, is there a seal? It was above 90 degrees when I drove it. Could it be related to heat?
Any help is appreciated Terry Attached thumbnail(s) |
iankarr |
Jul 26 2018, 08:47 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Behind that screw is the oil pressure relief valve. There should be a crush washer between the cap and the case. I think I see it peeking out around the cap. Try putting a new washer in and see if that helps. Or maybe some Yamabond. Just don't use a thin blade screwdriver to tighten the cap (like the PO did). Use a tool that matches the slot as closely as possible. What weight oil are you running? It's possible that thinner viscocity oil may leak more under hot conditions. Don't forget to check and top off your oil level.
tsvo |
Jul 26 2018, 09:37 PM
Behind that screw is the oil pressure relief valve. There should be a crush washer between the cap and the case. I think I see it peeking out around the cap. Try putting a new washer in and see if that helps. Or maybe some Yamabond. Just don't use a thin blade screwdriver to tighten the cap (like the PO did). Use a tool that matches the slot as closely as possible. What weight oil are you running? It's possible that thinner viscocity oil may leak more under hot conditions. Don't forget to check and top off your oil level. Thank you Ian. Sorry for the next dumb question. When I remove the screw to replace the washer will the car lose a lot of oil? |
Lo-Fi Version | Time is now: 16th June 2024 - 02:24 AM |
