Slight oil leak from screw next to oil filter, Oil leak |
tsvo |
Jul 26 2018, 08:43 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have a 1973 1.7. I noticed a small puddle on my garage floor this morning. I cleaned it up and have not seen any more. I looked under the car and I think it is coming from the small screen next to the oil filter. Can anyone tell me what this is and what I need to fix it? It seems tight, is there a seal? It was above 90 degrees when I drove it. Could it be related to heat?
Any help is appreciated Terry Attached thumbnail(s) |
a71914 |
Jul 27 2018, 07:48 AM
Newbie Group: Members Posts: 25 Joined: 17-September 03 From: Sterling, MA Member No.: 1,171 Region Association: North East States |
And be careful. The Pressure Relief Valve is spring loaded.
Keep a bit of tension on that screw when you near the end of the threads. Otherwise you will be looking for the parts all over the garage. Also, remember how the relief valve goes in. If it is put in incorrectly then you will have no oil pressure. |
Lo-Fi Version | Time is now: 16th June 2024 - 07:08 AM |
