Slight oil leak from screw next to oil filter, Oil leak |
tsvo |
Jul 26 2018, 08:43 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have a 1973 1.7. I noticed a small puddle on my garage floor this morning. I cleaned it up and have not seen any more. I looked under the car and I think it is coming from the small screen next to the oil filter. Can anyone tell me what this is and what I need to fix it? It seems tight, is there a seal? It was above 90 degrees when I drove it. Could it be related to heat?
Any help is appreciated Terry Attached thumbnail(s) |
iankarr |
Jul 27 2018, 08:09 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,482 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The crush washer is an unusual size. Number 22 in this diagram. you can also see the spring and piston which is part of this assembly...
http://www.autoatlanta.com/porsche-parts/h...;section=114-00 While you're in there (IMG:style_emoticons/default/smile.gif)...you may want to replace it with Tangerine's upgraded relief valve. Here's a link. If you speak with Chris, he may even throw in the new crush washer... http://www.tangerineracing.com/oilpressurerelief.htm Good luck! |
Lo-Fi Version | Time is now: 16th June 2024 - 07:24 AM |
