Cutch Tube repairs, See lots of these done, but WHY needed |
barefoot |
Aug 5 2018, 01:13 PM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
There's a plethora of repairs done to fix broken away clutch tubes, but there should never be any thrust load on this tube. It's just a conduit to route the cable thru the tunnel area.
Only thing i can think of is if the cable sheath in the engine bay is a little too long, then the fixing at the tranny bracket that also holds the pully to rotate the cable 180 Degrees is not adequately fixing the aft end of the sheath, then the thrust load pushes on the end of the clutch tube where it exits the firewall. I'm getting the the point of re-installing the engine and then can check if the sheath is loading against the tube and not the aft end fixing. Anyone been thru this already to help with this mystery ?? Inquiring minds want to know (IMG:style_emoticons/default/dry.gif) |
JeffBowlsby |
Aug 5 2018, 04:11 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
There are forces put on the clutch tube, find the center tunnel photos and you will see the geometry.
You must be mis-remembering Tom, there is no factory fix kit, no Factory Service Bulletin, or bulletin of any kind, for a clutch tube repair. The repairs done on the car in the photos...is unbelievable and I'glad you plan to redo. That's choosing my words carefully. See this for an easy, sanitary and durable repair -courtesy of Mike Mueller's skills with a welder Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:05 PM |
