| 9144me2enjoy |
Aug 5 2018, 08:34 PM
Member ![]() ![]() Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
1973 Porsche 914 2.0L. I’m removing my Oil Temp Gauge and installing a Oil Pressure Gauge. I installed a 100 psi VDO Oil Pressure Gauge. Do to the size of the new Sender Unit that fits a 100 psi VDO Gauge you cannot just insert it in the same location in the Taco Plate! I was able to drill a 7/16 hole in the same plate and install the new sender unit. I left the original sender unit where it was at and just removed the plug and placed it on the new 100 psi Oil Pressure Sending Unit. On the other end I just plugged the original harness back in the same 3 prong plug in on the back off the new VDO Oil pressure gauge. Sending unit wire to G and the + to fuse box etc. No reading on gauge! What’s wrong. The new sending unit is extended about 1/2” inside. Any suggestions. Thanks
73-914 no pressure in oil sump = GOOD THING Aug 5 2018, 09:02 PM
9144me2enjoy Could there be a problem with not getting enough o... Aug 5 2018, 09:32 PM
type2man
Could there be a problem with not getting enough ... Aug 5 2018, 09:48 PM
Mark Henry Oil pressure...from the pump...there's no oil ... Aug 5 2018, 09:51 PM
9144me2enjoy Thanks for all the valuable information, I was obv... Aug 5 2018, 09:56 PM
falcor75
I had a piece like this machined to elevate my ... Aug 6 2018, 01:08 AM
Jonathan Livesay
I had a piece like this machined to elevate my p... Aug 6 2018, 09:12 AM
Dave_Darling
I had a piece like this machined to elevate my pr... Aug 6 2018, 12:19 PM
barefoot
I had a piece like this machined to elevate my p... Aug 6 2018, 12:38 PM
bdstone914
[quote name='falcor75' post='2635834' date='Aug 6... Aug 6 2018, 05:53 PM
ClayPerrine I Vehemently Disagree.
More than 20 years ago, I... Apr 18 2019, 03:51 PM
914forme You need an extension, I have several of them here... Aug 6 2018, 10:12 AM
914forme My offer taken off the table BTW Aug 7 2018, 08:44 AM
malcolm2 I used a metal braided paint ball gun hose. They ... Aug 7 2018, 09:02 AM
9144me2enjoy Thanks for all the suggestions. I think I will go ... Aug 11 2018, 10:36 AM
ctc911ctc '74, 2.0L
Could someone please assist me in t... Apr 18 2019, 03:08 PM
ctc911ctc Any suggestions will be welcome, thanks in advance... Apr 19 2019, 10:12 AM
914forme If it is a proper metal the stand off are the best... Apr 19 2019, 09:07 AM
FlacaProductions https://www2.cip1.com/ProductDetails.asp?Pr...VDO%... Jul 26 2020, 01:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 02:32 PM |
