> Converting Oil Temp gauge to Oil Pressure Gauge?
9144me2enjoy
post Aug 5 2018, 08:34 PM
1973 Porsche 914 2.0L. I’m removing my Oil Temp Gauge and installing a Oil Pressure Gauge. I installed a 100 psi VDO Oil Pressure Gauge. Do to the size of the new Sender Unit that fits a 100 psi VDO Gauge you cannot just insert it in the same location in the Taco Plate! I was able to drill a 7/16 hole in the same plate and install the new sender unit. I left the original sender unit where it was at and just removed the plug and placed it on the new 100 psi Oil Pressure Sending Unit. On the other end I just plugged the original harness back in the same 3 prong plug in on the back off the new VDO Oil pressure gauge. Sending unit wire to G and the + to fuse box etc. No reading on gauge! What’s wrong. The new sending unit is extended about 1/2” inside. Any suggestions. Thanks
9144me2enjoy
post Aug 5 2018, 09:56 PM
Thanks for all the valuable information, I was obviously misdirected earlier. I will correct that error. Thank you.
9144me2enjoy   Converting Oil Temp gauge to Oil Pressure Gauge?   Aug 5 2018, 08:34 PM
73-914   no pressure in oil sump = GOOD THING   Aug 5 2018, 09:02 PM
9144me2enjoy   Could there be a problem with not getting enough o...   Aug 5 2018, 09:32 PM
type2man   Could there be a problem with not getting enough ...   Aug 5 2018, 09:48 PM
Mark Henry   Oil pressure...from the pump...there's no oil ...   Aug 5 2018, 09:51 PM
9144me2enjoy   Thanks for all the valuable information, I was obv...   Aug 5 2018, 09:56 PM
falcor75   I had a piece like this machined to elevate my ...   Aug 6 2018, 01:08 AM
Jonathan Livesay   I had a piece like this machined to elevate my p...   Aug 6 2018, 09:12 AM
Dave_Darling   I had a piece like this machined to elevate my pr...   Aug 6 2018, 12:19 PM
barefoot   I had a piece like this machined to elevate my p...   Aug 6 2018, 12:38 PM
bdstone914   [quote name='falcor75' post='2635834' date='Aug 6...   Aug 6 2018, 05:53 PM
ClayPerrine   I Vehemently Disagree. More than 20 years ago, I...   Apr 18 2019, 03:51 PM
914forme   You need an extension, I have several of them here...   Aug 6 2018, 10:12 AM
914forme   My offer taken off the table BTW   Aug 7 2018, 08:44 AM
malcolm2   I used a metal braided paint ball gun hose. They ...   Aug 7 2018, 09:02 AM
9144me2enjoy   Thanks for all the suggestions. I think I will go ...   Aug 11 2018, 10:36 AM
ctc911ctc   '74, 2.0L Could someone please assist me in t...   Apr 18 2019, 03:08 PM
ctc911ctc   Any suggestions will be welcome, thanks in advance...   Apr 19 2019, 10:12 AM
914forme   If it is a proper metal the stand off are the best...   Apr 19 2019, 09:07 AM
FlacaProductions   https://www2.cip1.com/ProductDetails.asp?Pr...VDO%...   Jul 26 2020, 01:48 PM
- Lo-Fi Version Time is now: 1st November 2026 - 02:32 PM
