> Converting Oil Temp gauge to Oil Pressure Gauge?
9144me2enjoy
post Aug 5 2018, 08:34 PM
1973 Porsche 914 2.0L. I’m removing my Oil Temp Gauge and installing a Oil Pressure Gauge. I installed a 100 psi VDO Oil Pressure Gauge. Do to the size of the new Sender Unit that fits a 100 psi VDO Gauge you cannot just insert it in the same location in the Taco Plate! I was able to drill a 7/16 hole in the same plate and install the new sender unit. I left the original sender unit where it was at and just removed the plug and placed it on the new 100 psi Oil Pressure Sending Unit. On the other end I just plugged the original harness back in the same 3 prong plug in on the back off the new VDO Oil pressure gauge. Sending unit wire to G and the + to fuse box etc. No reading on gauge! What’s wrong. The new sending unit is extended about 1/2” inside. Any suggestions. Thanks
falcor75
post Aug 6 2018, 01:08 AM
I had a piece like this machined to elevate my pressure sender from the stock idiot light location. The sender has two outputs, one for the gauge and one for the idiot light.
Mounted it looks like this.
Dave_Darling
post Aug 6 2018, 12:19 PM
914 Idiot
QUOTE(falcor75 @ Aug 6 2018, 12:08 AM) *
Not a good idea. Now you have the weight of the sender and extension pipe all working on the little pipe threads in the case. The pipe acts as a lever arm, even though a short one, and the vibration can eventually damage the threads or the hole in the case.
The flexible hose is a better idea, though you do have to make sure to ground the outside of the sender.
--DD
9144me2enjoy   Converting Oil Temp gauge to Oil Pressure Gauge?   Aug 5 2018, 08:34 PM
73-914   no pressure in oil sump = GOOD THING   Aug 5 2018, 09:02 PM
9144me2enjoy   Could there be a problem with not getting enough o...   Aug 5 2018, 09:32 PM
type2man   Could there be a problem with not getting enough ...   Aug 5 2018, 09:48 PM
Mark Henry   Oil pressure...from the pump...there's no oil ...   Aug 5 2018, 09:51 PM
9144me2enjoy   Thanks for all the valuable information, I was obv...   Aug 5 2018, 09:56 PM
falcor75   I had a piece like this machined to elevate my ...   Aug 6 2018, 01:08 AM
Jonathan Livesay   I had a piece like this machined to elevate my p...   Aug 6 2018, 09:12 AM
Dave_Darling   I had a piece like this machined to elevate my pr...   Aug 6 2018, 12:19 PM
barefoot   I had a piece like this machined to elevate my p...   Aug 6 2018, 12:38 PM
bdstone914   [quote name='falcor75' post='2635834' date='Aug 6...   Aug 6 2018, 05:53 PM
ClayPerrine   I Vehemently Disagree. More than 20 years ago, I...   Apr 18 2019, 03:51 PM
914forme   You need an extension, I have several of them here...   Aug 6 2018, 10:12 AM
914forme   My offer taken off the table BTW   Aug 7 2018, 08:44 AM
malcolm2   I used a metal braided paint ball gun hose. They ...   Aug 7 2018, 09:02 AM
9144me2enjoy   Thanks for all the suggestions. I think I will go ...   Aug 11 2018, 10:36 AM
ctc911ctc   '74, 2.0L Could someone please assist me in t...   Apr 18 2019, 03:08 PM
ctc911ctc   Any suggestions will be welcome, thanks in advance...   Apr 19 2019, 10:12 AM
914forme   If it is a proper metal the stand off are the best...   Apr 19 2019, 09:07 AM
FlacaProductions   https://www2.cip1.com/ProductDetails.asp?Pr...VDO%...   Jul 26 2020, 01:48 PM
- Lo-Fi Version Time is now: 1st November 2026 - 02:31 PM
