| 9144me2enjoy |
Aug 5 2018, 08:34 PM
Member ![]() ![]() Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
1973 Porsche 914 2.0L. I’m removing my Oil Temp Gauge and installing a Oil Pressure Gauge. I installed a 100 psi VDO Oil Pressure Gauge. Do to the size of the new Sender Unit that fits a 100 psi VDO Gauge you cannot just insert it in the same location in the Taco Plate! I was able to drill a 7/16 hole in the same plate and install the new sender unit. I left the original sender unit where it was at and just removed the plug and placed it on the new 100 psi Oil Pressure Sending Unit. On the other end I just plugged the original harness back in the same 3 prong plug in on the back off the new VDO Oil pressure gauge. Sending unit wire to G and the + to fuse box etc. No reading on gauge! What’s wrong. The new sending unit is extended about 1/2” inside. Any suggestions. Thanks
| falcor75 |
Aug 6 2018, 01:08 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
I had a piece like this machined to elevate my pressure sender from the stock idiot light location. The sender has two outputs, one for the gauge and one for the idiot light. ![]() Mounted it looks like this. |
| Dave_Darling |
Aug 6 2018, 12:19 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I had a piece like this machined to elevate my pressure sender from the stock idiot light location. The sender has two outputs, one for the gauge and one for the idiot light. Not a good idea. Now you have the weight of the sender and extension pipe all working on the little pipe threads in the case. The pipe acts as a lever arm, even though a short one, and the vibration can eventually damage the threads or the hole in the case. The flexible hose is a better idea, though you do have to make sure to ground the outside of the sender. --DD |
| barefoot |
Aug 6 2018, 12:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
I had a piece like this machined to elevate my pressure sender from the stock idiot light location. The sender has two outputs, one for the gauge and one for the idiot light. Not a good idea. Now you have the weight of the sender and extension pipe all working on the little pipe threads in the case. The pipe acts as a lever arm, even though a short one, and the vibration can eventually damage the threads or the hole in the case. The flexible hose is a better idea, though you do have to make sure to ground the outside of the sender. --DD I agree, That elevated sender held by that pipe thread is a fatigue machine waiting for enough cycles before the fitting fractures right at the thread where in emerges from the case. Remember, lots of vibration going on in that location, so positive/ negative stress cycles occurring then major oil leak !! |
9144me2enjoy Converting Oil Temp gauge to Oil Pressure Gauge? Aug 5 2018, 08:34 PM
73-914 no pressure in oil sump = GOOD THING Aug 5 2018, 09:02 PM
9144me2enjoy Could there be a problem with not getting enough o... Aug 5 2018, 09:32 PM
type2man
Could there be a problem with not getting enough ... Aug 5 2018, 09:48 PM
Mark Henry Oil pressure...from the pump...there's no oil ... Aug 5 2018, 09:51 PM
9144me2enjoy Thanks for all the valuable information, I was obv... Aug 5 2018, 09:56 PM
Jonathan Livesay
I had a piece like this machined to elevate my p... Aug 6 2018, 09:12 AM
bdstone914
[quote name='falcor75' post='2635834' date='Aug 6... Aug 6 2018, 05:53 PM
ClayPerrine I Vehemently Disagree.
More than 20 years ago, I... Apr 18 2019, 03:51 PM
914forme You need an extension, I have several of them here... Aug 6 2018, 10:12 AM
914forme My offer taken off the table BTW Aug 7 2018, 08:44 AM
malcolm2 I used a metal braided paint ball gun hose. They ... Aug 7 2018, 09:02 AM
9144me2enjoy Thanks for all the suggestions. I think I will go ... Aug 11 2018, 10:36 AM
ctc911ctc '74, 2.0L
Could someone please assist me in t... Apr 18 2019, 03:08 PM
ctc911ctc Any suggestions will be welcome, thanks in advance... Apr 19 2019, 10:12 AM
914forme If it is a proper metal the stand off are the best... Apr 19 2019, 09:07 AM
FlacaProductions https://www2.cip1.com/ProductDetails.asp?Pr...VDO%... Jul 26 2020, 01:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 02:33 PM |
