| Jimz73 |
Aug 6 2018, 06:58 PM
Newbie ![]() Group: Members Posts: 10 Joined: 15-April 03 From: Maumee, Oh. Member No.: 575 |
Okay, I am totally stumped and dumb-founded. My car hasn't run for at least 2 years. I replaced the three port fuel pump with a new 2 port pump. The car is a '73 1.7 with stock fuel injection. I replaced fuel lines in tunnel with stainless steel lines at the same time. Tried to start, just cranked and cranked. It is getting gas to the injectors, but I could not get spark. I replaced the coil with a new one. Pulled lead from distributor and placed near the engine tin. Cranked the engine over, no spark. Car ran fine when I garaged it due to leaking fuel pump. I need help to figure it out. I even tried starting fluid and no go. Hasn't even made an attempt to fire.
| marksteinhilber |
Aug 6 2018, 08:56 PM
Member ![]() ![]() Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
You must confirm that you have 12v to the coil when ignition is on. If you have 12v to the coil, then you would check your points and condenser. The points should be opening and closing as engine cranks. An inductive timing light or spark tester can be used on the main coil to distributor lead. If there is no spark here, the problem is between the coil and the distributor and likely the points and condenser. If you sense spark getting to the center of the distributor cap, but no spark sensed in the plug wires, then you may have a bad rotor, cap, or wire connections at cap. Also make sure distributor is seated down, and rotor turns with engine. Make sure rotor lines up with TDC #1. As you check these parts realize that even the rotor and cap may have failed fail and won’t pass the spark. When I have no spark on an old car that hasn’t run in years, it can be as simple as rubbing the contact points with emery paper.
| Jimz73 |
Aug 7 2018, 08:29 AM
You must confirm that you have 12v to the coil when ignition is on. If you have 12v to the coil, then you would check your points and condenser. The points should be opening and closing as engine cranks. An inductive timing light or spark tester can be used on the main coil to distributor lead. If there is no spark here, the problem is between the coil and the distributor and likely the points and condenser. If you sense spark getting to the center of the distributor cap, but no spark sensed in the plug wires, then you may have a bad rotor, cap, or wire connections at cap. Also make sure distributor is seated down, and rotor turns with engine. Make sure rotor lines up with TDC #1. As you check these parts realize that even the rotor and cap may have failed fail and won’t pass the spark. When I have no spark on an old car that hasn’t run in years, it can be as simple as rubbing the contact points with emery paper. I just confirmed that I do not have 12V to the coil. I connected red lead to the + side of coil and black to engine tin, and with the key in the on position. No voltage registered at all. |
Jimz73 I have no spark Aug 6 2018, 06:58 PM
The Cabinetmaker Point Gap closed or corroded, or bad condenser Aug 6 2018, 08:22 PM
Rand Lots of talk about fuel when you indicated it was ... Aug 6 2018, 08:29 PM
taylspin46
You must confirm that you have 12v to the coil w... Aug 7 2018, 09:36 AM
Larmo63 Also, look inside the distributor cap at the cente... Aug 6 2018, 09:11 PM
marksteinhilber
Also, look inside the distributor cap at the cent... Aug 6 2018, 09:22 PM
cary I'm with Curt. Just ran into that on Mick... Aug 6 2018, 10:37 PM
Dave_Darling Step 1: Verify that there is no spark An extra s... Aug 6 2018, 11:30 PM
Chris914n6 After 2 years of Obamagas anotherthingBushdidwrong... Aug 6 2018, 11:32 PM
914_teener
After 2 years of Obamagas the injectors are likel... Aug 7 2018, 04:50 PM
Chris914n6
[quote name='Chris914n6' post='2636176' date='Aug... Aug 7 2018, 07:41 PM
914_teener
[quote name='Chris914n6' post='2636176' date='Au... Aug 7 2018, 11:53 PM
ClayPerrine
[quote name='Chris914n6' post='2636452' date='Aug... Aug 8 2018, 10:16 AM
Bartlett 914
[quote name='Chris914n6' post='2636452' date='Au... Aug 8 2018, 10:40 AM
ClayPerrine
I Agree but I think it would have been better if ... Aug 8 2018, 11:07 AM
SirAndy When someone slips in this political BS the admin... Aug 8 2018, 11:18 AM
dr914@autoatlanta.com first make sure that in the crank position you sti... Aug 7 2018, 08:30 AM
taylspin46 Ignition coil gets power from fuse9 via ignition c... Aug 7 2018, 09:41 AM
taylspin46
Ignition coil gets power from fuse9 via ignition ... Aug 7 2018, 09:42 AM
taylspin46 Meant poer to S9 from ign. Switch. Aug 7 2018, 09:48 AM
Jimz73 Thanks to all of you. I checked batteries in my me... Aug 7 2018, 11:02 AM
Chris914n6 Also let it run 10-30 minutes to clean the old gas... Aug 7 2018, 01:50 PM
The Cabinetmaker What did you gap the points at. Fsm says to set dw... Aug 7 2018, 02:01 PM
cary Well done ..................
Don't forget to ... Aug 7 2018, 11:56 PM
Jimz73
Don't forget to... Aug 8 2018, 06:46 AM
cary I was meaning all the rest of the lines. The rubbe... Aug 8 2018, 07:17 AM
ClayPerrine I would look into an electronic ignition to replac... Aug 8 2018, 11:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:06 PM |
