> I have no spark, No Spark
Jimz73
post Aug 6 2018, 06:58 PM
Okay, I am totally stumped and dumb-founded. My car hasn't run for at least 2 years. I replaced the three port fuel pump with a new 2 port pump. The car is a '73 1.7 with stock fuel injection. I replaced fuel lines in tunnel with stainless steel lines at the same time. Tried to start, just cranked and cranked. It is getting gas to the injectors, but I could not get spark. I replaced the coil with a new one. Pulled lead from distributor and placed near the engine tin. Cranked the engine over, no spark. Car ran fine when I garaged it due to leaking fuel pump. I need help to figure it out. I even tried starting fluid and no go. Hasn't even made an attempt to fire.
Chris914n6
post Aug 6 2018, 11:32 PM
Jackstands are my life.
After 2 years of Obamagas anotherthingBushdidwronggas EPAhatesoldcarsgas E10 the injectors are likely stuck and need cleaned.*
Also get one of these, cheap and easy In-Line Spark Checker
*(edited for Political Correctness)
914_teener
post Aug 7 2018, 04:50 PM
QUOTE(Chris914n6 @ Aug 6 2018, 10:32 PM) *
After 2 years of Obamagas the injectors are likely stuck and need cleaned.
Your political views have nothing to do with why the OP has no spark.
Keep them to yourself.
To the OP:
Check the ground lead on the advance plate to make sure it is connected and do what Dave Darling says first.
Chris914n6
post Aug 7 2018, 07:41 PM
QUOTE(914_teener @ Aug 7 2018, 03:50 PM) *
There is nothing political about the ethanol mandate destroying fuel systems of cars built before it. I just did a fuel pump on a 2005 Beetle that sat for 2 years, the plastic transfer tube crumbled and the rubber melted. Common pieces in all German cars.
Also I stepped in the puddle and it left half my sole in the concrete. It's also a problem for the couple cars I don't drive often.
OP mentioned he had 2 year old gas.... it is relevant if it's not squirting or has pre-ethanol hoses.
914_teener
post Aug 7 2018, 11:53 PM
QUOTE(Chris914n6 @ Aug 7 2018, 06:41 PM) *
I'm calling it out. You wrote Obamagas. WTF....now you are gonna say that's not political.
For what it is worth, the Ethanol mandate was in 2005. So why don't we just call it Bushgas?
Gotta blame someone right?
ClayPerrine
post Aug 8 2018, 10:16 AM
QUOTE(914_teener @ Aug 8 2018, 12:53 AM) *
Ok.. both of you need to stop this conversation. If you keep it up, I am going to have to lock this thread, and I don't want to do it.
(IMG:style_emoticons/default/post-2-1137106233.gif)
So how about we just drop this part and make it easier on everyone.
Bartlett 914
post Aug 8 2018, 10:40 AM
QUOTE(ClayPerrine @ Aug 8 2018, 11:16 AM) *
I Agree but I think it would have been better if you had spoken up first. When someone slips in this political BS the admins should step in and not leave it to a member to speak up first. I was a little pissed at the comment but kept it to myself.
ClayPerrine
post Aug 8 2018, 11:07 AM
QUOTE(Bartlett 914 @ Aug 8 2018, 11:40 AM) *
Actually, I have been watching this thread. I was hoping that comment would just be ignored. I guess I was unlucky.
Like the cops, we can't be everywhere all the time. So if you see something, just drop one of us a note so we know what is going on. We can either edit the comment or delete it, and admonish the poster.
Now, we have a member here with a problem relating to his car. Let's concentrate on it.
Jimz73   I have no spark   Aug 6 2018, 06:58 PM
The Cabinetmaker   Point Gap closed or corroded, or bad condenser   Aug 6 2018, 08:22 PM
Rand   Lots of talk about fuel when you indicated it was ...   Aug 6 2018, 08:29 PM
marksteinhilber   You must confirm that you have 12v to the coil whe...   Aug 6 2018, 08:56 PM
Jimz73   You must confirm that you have 12v to the coil wh...   Aug 7 2018, 08:29 AM
taylspin46   You must confirm that you have 12v to the coil w...   Aug 7 2018, 09:36 AM
Larmo63   Also, look inside the distributor cap at the cente...   Aug 6 2018, 09:11 PM
marksteinhilber   Also, look inside the distributor cap at the cent...   Aug 6 2018, 09:22 PM
cary   I'm with Curt. Just ran into that on Mick...   Aug 6 2018, 10:37 PM
Dave_Darling   Step 1: Verify that there is no spark An extra s...   Aug 6 2018, 11:30 PM
Chris914n6   After 2 years of Obamagas anotherthingBushdidwrong...   Aug 6 2018, 11:32 PM
914_teener   After 2 years of Obamagas the injectors are likel...   Aug 7 2018, 04:50 PM
Chris914n6   [quote name='Chris914n6' post='2636176' date='Aug...   Aug 7 2018, 07:41 PM
914_teener   [quote name='Chris914n6' post='2636176' date='Au...   Aug 7 2018, 11:53 PM
ClayPerrine   [quote name='Chris914n6' post='2636452' date='Aug...   Aug 8 2018, 10:16 AM
Bartlett 914   [quote name='Chris914n6' post='2636452' date='Au...   Aug 8 2018, 10:40 AM
ClayPerrine   I Agree but I think it would have been better if ...   Aug 8 2018, 11:07 AM
SirAndy   When someone slips in this political BS the admin...   Aug 8 2018, 11:18 AM
dr914@autoatlanta.com   first make sure that in the crank position you sti...   Aug 7 2018, 08:30 AM
taylspin46   Ignition coil gets power from fuse9 via ignition c...   Aug 7 2018, 09:41 AM
taylspin46   Ignition coil gets power from fuse9 via ignition ...   Aug 7 2018, 09:42 AM
taylspin46   Meant poer to S9 from ign. Switch.   Aug 7 2018, 09:48 AM
Jimz73   Thanks to all of you. I checked batteries in my me...   Aug 7 2018, 11:02 AM
Chris914n6   Also let it run 10-30 minutes to clean the old gas...   Aug 7 2018, 01:50 PM
The Cabinetmaker   What did you gap the points at. Fsm says to set dw...   Aug 7 2018, 02:01 PM
cary   Well done .................. Don't forget to ...   Aug 7 2018, 11:56 PM
Jimz73   Well done .................. Don't forget to...   Aug 8 2018, 06:46 AM
cary   I was meaning all the rest of the lines. The rubbe...   Aug 8 2018, 07:17 AM
ClayPerrine   I would look into an electronic ignition to replac...   Aug 8 2018, 11:14 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:30 PM
