| 914_7T3 |
Aug 5 2018, 02:26 PM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,894 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
Looking for a replacement solution to the original fuel tank pads that retain moisture and rust the tank from the outside in.
Was thinking about some type of rubber padding that may be used similar to the below. Would also like to line the top of the battery tray with it as well. Any thoughts? Waxman 2-Pack 4-in Black Rubber Pads (w/ adhesive backing) ![]() |
| 914_7T3 |
Aug 9 2018, 11:18 AM
So what is the consensus as to which material is more suitable, neoprene or polyester felt and what would be the recommended thickness?
| Rand |
Aug 9 2018, 12:37 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
So what is the consensus as to which material is more suitable, neoprene or polyester felt and what would be the recommended thickness? It's pretty clear that felt is out and neoprene wins. Old wet suits are perfect if you can find them. Free often. Mouse pads are dirt cheap, and some may need the fabric ripped away if it could trap moisture or at least put back to back so only the neoprene touches anything. Thickness isn't super critical, think similar to original but with better material. |
914 7T3 Fuel Tank Pads: Aug 5 2018, 02:26 PM
mepstein I’m using self adhesive rubber. So much better t... Aug 5 2018, 03:00 PM
raynekat There's no way water should be getting on thos... Aug 8 2018, 05:29 PM
Rand mouse pads? :P Aug 8 2018, 05:36 PM
Dave_Darling It may be that water should never get on those--bu... Aug 8 2018, 05:53 PM
Rand mouse pads :lol: (cheap neoprine cut into nicely p... Aug 8 2018, 05:55 PM
bbrock You guys aren't worried about the neoprene wic... Aug 8 2018, 06:28 PM
URY914 The original felt pads got wet and the tank had pi... Aug 8 2018, 06:44 PM
Larmo63 I used old wetsuit material (neoprene) when my tan... Aug 8 2018, 07:54 PM
914 7T3
I used old wetsuit material (neoprene) when my ta... Aug 9 2018, 11:14 AM
ValcoOscar
I used old wetsuit material (neoprene) when my ta... Aug 10 2018, 12:48 PM
bbrock I think I might go for something more like this ht... Aug 8 2018, 08:27 PM
mepstein https://www.grainger.com/product/E-JAMES-EP...;sea... Aug 8 2018, 08:35 PM
ClayPerrine Please don't use the felt again. Over the win... Aug 9 2018, 09:28 AM
bbrock I know i'm speaking alone here but I have seri... Aug 9 2018, 12:53 PM
raynekat
I know i'm speaking alone here but I have ser... Aug 9 2018, 01:08 PM
76-914
I know i'm speaking alone here but I have se... Aug 9 2018, 01:55 PM
bbrock
[quote name='bbrock' post='2636965' date='Aug 9 2... Aug 9 2018, 02:00 PM
Rand
This raises a question. Why should that area get... Aug 9 2018, 02:33 PM
bbrock
This raises a question. Why should that area ge... Aug 9 2018, 04:29 PM
914 7T3
This raises a question. Why should that area ge... Aug 10 2018, 10:31 PM
Larmo63 A) My trunk doesn't leak
B) My car is garaged ... Aug 9 2018, 01:45 PM
ConeDodger
B) My car is garaged... Aug 10 2018, 01:43 PM
raynekat Wow Brent....that's a lot of science. I think ... Aug 9 2018, 04:41 PM
Rand Here's another perspective. We know the felt j... Aug 9 2018, 05:01 PM
bbrock
Here's another perspective. We know the felt ... Aug 9 2018, 08:20 PM
ClayPerrine Just glue the neoprene to the tank. That way it wo... Aug 9 2018, 08:34 PM
marksteinhilber
Just glue the neoprene to the tank. That way it w... Aug 10 2018, 11:34 AM
914Toy I used Scotch pad, which I guess will not wick. Aug 10 2018, 01:33 PM
914_7T3 Wanted to update this thread with the chosen solut... Jan 7 2019, 10:46 PM
injunmort I used an old inner tube cut to size, doubled up a... Jan 8 2019, 02:37 PM
amfab deleted-duplicate post Jan 8 2019, 03:35 PM
amfab deleted Jan 8 2019, 03:35 PM
amfab what about 3M Nomad mat material
This Stuff:
Jan 8 2019, 03:36 PM
Chi-town 10% Ethanol gasoline is hygroscopic (will absorb w... Jan 8 2019, 05:54 PM
cuddy_k My gas tank compartment has actually been a mouse ... Jan 8 2019, 07:47 PM
saigon71 I cut pipe insulation down into squares for where ... Jan 9 2019, 11:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:37 PM |
