Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
I am beyond frustrated! For some reason i can get a reading from my O2 sensor into my ECU.
I purchased a new ECU and O2 sensor and controller and I am getting the same results. Traced every wire looking for faults or shorts. I know i am putting the correct voltage to the correct pin on the ECU but I never see any response. I know the calibration is correct as the O2 is a LC2 which is programable and the dash gauge reads exactly what it should. I can set it to dual wide band and see the 2nd gauge respond perfectly but the gauge that is set to the local (pin 34) reads no voltage. Does anyone have know if you can set the input for the O2 gauge to a different input? Pin 5 is identified as SPARE input 2 as a ADC(ADC7). The options in Tuner Studios only give local and Remote ADC1,2,3... as options. None of these will pick up the signal i can confirm is going to pin 5. Same with pin 29 Spare Input 1. When i select dual wide bands i can get the SPARE ADC or Spare ADC2 to pick up the signal on the 2nd sensor port but no setting on the 1st port will result in a response. I am just completely baffled and have spent over $800 and have gotten no results. Can’t find anything in the settings that wold cause this issue. |
Mblizzard |
Well as frustrating as it was, for some reason it now works? (IMG:style_emoticons/default/WTF.gif)
Went back out and checked connections and did not fix anything but it started up and has run ever since? |
Lo-Fi Version | Time is now: 7th July 2025 - 08:25 AM |
