> MicroSquirt Help, Losing My F#@king Mind
Mblizzard
post Aug 11 2018, 07:38 PM
I am beyond frustrated! For some reason i can get a reading from my O2 sensor into my ECU.
I purchased a new ECU and O2 sensor and controller and I am getting the same results.
Traced every wire looking for faults or shorts. I know i am putting the correct voltage to the correct pin on the ECU but I never see any response. I know the calibration is correct as the O2 is a LC2 which is programable and the dash gauge reads exactly what it should.
I can set it to dual wide band and see the 2nd gauge respond perfectly but the gauge that is set to the local (pin 34) reads no voltage.
Does anyone have know if you can set the input for the O2 gauge to a different input?
Pin 5 is identified as SPARE input 2 as a ADC(ADC7). The options in Tuner Studios only give local and Remote ADC1,2,3... as options. None of these will pick up the signal i can confirm is going to pin 5. Same with pin 29 Spare Input 1.
When i select dual wide bands i can get the SPARE ADC or Spare ADC2 to pick up the signal on the 2nd sensor port but no setting on the 1st port will result in a response.
I am just completely baffled and have spent over $800 and have gotten no results. Can’t find anything in the settings that wold cause this issue.
DRPHIL914
post Aug 13 2018, 10:46 AM
Dr. Phil
hey mike, did you keep your d-jet, just in case? (IMG:style_emoticons/default/poke.gif)
was going to this mega-squirt supposed to reduce issues and give
some dependability? I hope you can get it working as we would hate for you
to drive a VWgolf or whatever to Okteenerfest!! -
Mblizzard
post Aug 13 2018, 10:54 AM
QUOTE(Philip W. @ Aug 13 2018, 08:46 AM) *
Says the guy who is having some frustration with door seals?
Yes I kept it but this engine is well beyond the capacity for it to run. Seems to be a self inflicted problem here. But it already makes more power than a stock 6. And it sounds awesome!
- Lo-Fi Version Time is now: 7th July 2025 - 08:31 AM
