Beakster |
Member ![]() ![]() Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None ![]() |
I have two 1.7 engine Blocks
the one in pieces Case n# is EA064290 The other in the car is EB005450 Would anyone have more info on engines by the Case numbers ?? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
All Type four cases are basically the same with small differences.
-some very early 411 cases were mag and had no windage tray provisions, very rare. -bus cases have different drilling for dipstick, oil fill, fuel pump (carb), lifter pressure relief (late cases not drilled),etc. -similar differences as bus for 411/412 cases. Biggest issue with using bus or 411/412 cases in a 914 is the dipstick tube. For 914 the only difference in the 1.7,1.8, 2.0 cases is where the serial number is. I don't know for sure but the euro carbed 914 may have the fuel pump area machined for the mechanical pump. The 1.7 "E'' cases are a great foundation for a build go 1.7/1.8 are the often best cases for any build, the shorter stroke crank is stronger and has less flex than the longer 2.0 crank, therefore causing less wear to the case. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,032 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
All Type four cases are basically the same with small differences. -some very early 411 cases were mag and had no windage tray provisions, very rare. -bus cases have different drilling for dipstick, oil fill, fuel pump (carb), lifter pressure relief (late cases not drilled),etc. For 914 the only difference in the 1.7,1.8, 2.0 cases is where the serial number is. I don't know for sure but the euro carbed 914 may have the fuel pump area machined for the mechanical pump. The 1.7 "E'' cases are a great foundation for a build go 1.7/1.8 are the often best cases for any build, the shorter stroke crank is stronger and has less flex than the longer 2.0 crank, therefore causing less wear to the case. (IMG:style_emoticons/default/agree.gif) I saw a VW 412, 1.8L case that had the mechanical fuel pump that mounts to the rear of the case. |
Mark Henry |
All Type four cases are basically the same with small differences. -some very early 411 cases were mag and had no windage tray provisions, very rare. -bus cases have different drilling for dipstick, oil fill, fuel pump (carb), lifter pressure relief (late cases not drilled),etc. For 914 the only difference in the 1.7,1.8, 2.0 cases is where the serial number is. I don't know for sure but the euro carbed 914 may have the fuel pump area machined for the mechanical pump. The 1.7 "E'' cases are a great foundation for a build go 1.7/1.8 are the often best cases for any build, the shorter stroke crank is stronger and has less flex than the longer 2.0 crank, therefore causing less wear to the case. (IMG:style_emoticons/default/agree.gif) I saw a VW 412, 1.8L case that had the mechanical fuel pump that mounts to the rear of the case. Sure it wasn't a bus case? 411/412 used an early D-jet FI system in north america. Bus had carbs till 75 and the mechanical fuel pump. |
Lo-Fi Version | Time is now: 11th July 2025 - 05:34 AM |
