| echocanyons |
Aug 15 2018, 02:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,115 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
I am planning to do an EFI conversion on a 1.8L type four.
What manifold options are available to adapt ITBs to the T4 four bolt heads? I think that I prefer the jenvey ITBs but would like to draw from the groups experience. Thanks |
| JamesM |
Aug 15 2018, 04:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,190 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Jenveys are really pretty, well made parts but after playing with the pair that wound up on my buddies 2270 I personally would probably try one of the cheaper bolt on options.
Couple things to be aware of: 1. The linkage arms/throttle shafts are not compatible with the Weber parts, not a problem if you are using the Jenvey arms but we ran into an issue when attempting to use the Tangerine cable linkage. Chris Foley was cool enough to put together a custom kit after we shipped him the Jenveys to work off of, but be aware that off the shelf parts may not be bolt on. This also includes air filters and velocity stacks. 2. The Jenveys need to have the airflow syncd per barrel where as the CBs appear to have a port that syncs the two barrels in each TB (and also both barrels tie into a single vacuum port) Not a huge deal but would make syncing the CB parts a bit easier. I haven't personally used the CB parts yet (though i have a plan to) but between the custom parts needed to utilize the Jenveys as well as the design the CB parts appear to be both cheaper and easier to use. Jenveys sure are pretty though. |
echocanyons Jenvey ITBs for four bolt T4 heads Aug 15 2018, 02:01 PM
Nogoodwithusernames
I am planning to do an EFI conversion on a 1.8L t... Aug 15 2018, 03:00 PM
rhodyguy The intake manifolds in the Dub shop picture are C... Aug 15 2018, 04:02 PM
Mueller EMPI or anyplace that sells Weber or Weber knock o... Aug 15 2018, 04:05 PM
echocanyons Great information so far.
I’ll definitely have ... Aug 15 2018, 11:01 PM
falcor75 Syncing per barrel is in my opinion prefered. My I... Aug 15 2018, 11:29 PM
Mark Henry Are you planing on a big engine build?
ITB's ... Aug 16 2018, 06:14 AM
Vacca Rabite Also questioning the use of ITBs on an otherwise s... Aug 16 2018, 07:20 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 03:12 PM |
