| echocanyons |
Aug 15 2018, 02:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,115 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
I am planning to do an EFI conversion on a 1.8L type four.
What manifold options are available to adapt ITBs to the T4 four bolt heads? I think that I prefer the jenvey ITBs but would like to draw from the groups experience. Thanks |
| VaccaRabite |
Aug 16 2018, 07:20 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Also questioning the use of ITBs on an otherwise stock 1.8. Its getting the worst of both worlds with no real upswing.
You get the loud howl of carbs, the finicky balancing act and a ton of moving parts that can fail or go out of alignment, combined with a harder to tune EFI system. I'm using a stock 1.8 plenum and intake runners and throttle body on my custom EFI build, except on a 2056 that is putting 130hp at the wheels (and I have a dyno chart to prove it). Using stock parts, only one throttle body, and a simple plenum to pull vacuum from. And you probably have all that stuff on hand and don't need to buy crazy expensive psuedo-carbs. Zach |
echocanyons Jenvey ITBs for four bolt T4 heads Aug 15 2018, 02:01 PM
Nogoodwithusernames
I am planning to do an EFI conversion on a 1.8L t... Aug 15 2018, 03:00 PM
rhodyguy The intake manifolds in the Dub shop picture are C... Aug 15 2018, 04:02 PM
Mueller EMPI or anyplace that sells Weber or Weber knock o... Aug 15 2018, 04:05 PM
JamesM Jenveys are really pretty, well made parts but aft... Aug 15 2018, 04:50 PM
echocanyons Great information so far.
I’ll definitely have ... Aug 15 2018, 11:01 PM
falcor75 Syncing per barrel is in my opinion prefered. My I... Aug 15 2018, 11:29 PM
Mark Henry Are you planing on a big engine build?
ITB's ... Aug 16 2018, 06:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 01:24 PM |
