> Tale of 3 Starter Motors, All three in the end, act the same way
ctc911ctc
post Aug 18 2018, 12:57 PM
[size=3]First some Facts
1974 2L, Barn Find, Last ran in 1988, ~20K miles
Rebuild the entire fuel system tank to injectors
Car will start - First start was yesterday, today ran for about 30 seconds
When we first energized the starter it would rotate the engine. Periodically there would be load CLANKS which would freeze the starter. The kind people in this forum suggested a new starter. NP, got a new one.
The second starter also CLANKED and then Broke! Ear came off of one of the mounts (see pic).
Soooooo, took it back and ordered another one - this took about an hour at the store to explain and then a day to get the new one from the 'warehouse'.
Installed the 3rd starter, the engine started - lots of white smoke after the blue Miracle Oil burned off. Engine stopped, tried to start it again and the Starter CLANKED and then froze. When I try to energize the starter it pulls about 500amps and just clicks. There is no whir or rotation at all - just the click of the solenoid.
Starter 1. CLANK and then Froze
Starter 2. CLANK, Froze and then the ear broke
Starter 3. CLANK, Froze.
For each of these when the starter is taken OUT of the car, it will operate on the bench perfectly. When put back in the car will operate until it CLANKS and freezes.
SOOOOOOOOooooooooooooo,
Has anyone had experience with a starter gear getting wedged on the flywheel?
I have rotated the engine with the starter out of the car and all of the flywheel teeth look perfect.
My ideas:
1. The flywheel and the starter gear are not perfectly aligned and the two gears when they engage are so close to each other and the gears wedge?
2. The Flywheel has come loose and perhaps moving so it strikes the housing and this freezes the rotation
3. Something entirely different that I could not have foreseen that the great minds within this list will roll their eyes and then tell me to check: XYZ
Many thanks in advance!
CTC
TheCabinetmaker
post Aug 18 2018, 02:41 PM
I drive my car everyday
It might just be your fuzzy pic, but that flywheel looks like someone took a grinder to it. Clear pic of the teeth please?
ctc911ctc
post Aug 18 2018, 02:55 PM
QUOTE(The Cabinetmaker @ Aug 18 2018, 02:41 PM) *
Will do - grease is in the teeth in the pic - all are in very good shap
- Lo-Fi Version Time is now: 3rd September 2025 - 01:55 PM
