> Not a 914 but need brain trust help...., 944 turbo oli won't show on dip stick.....
second wind
post Aug 17 2018, 07:39 PM
I know I am off topic by one digit but maybe someone can help....I just changed the oil in my '89 944 turbo and have put at least 7.5 quarts of oil into it....but it doesn't hit the dip stick yet. Never had this problem before. No leaks or anything....good oil pressure....and even if the new oil is so clean you couldn't see it it would still be wet and shiny....which it isn't. I am afraid to put more oil in.....most sources say 6.5 quarts should do it.....anybody have any ideas on this? Very weird....
Thank you,
gg
rgalla9146
post Aug 19 2018, 09:28 AM
I'm sure you would have mentioned it but......is it a new engine ?...did you replace the oil pan ? either one would require some additional oil.
second wind   Not a 914 but need brain trust help....   Aug 17 2018, 07:39 PM
cuddy_k   Strange.Is it possible the PO added a deep oil pan...   Aug 17 2018, 08:40 PM
michael7810   The dipstick tube could be coming out of the block...   Aug 17 2018, 08:54 PM
worn   I know I am off topic by one digit but maybe some...   Aug 17 2018, 09:18 PM
914-300Hemi   It also depends on if you have front oil cooler. ...   Aug 17 2018, 09:36 PM
bdstone914   Over filling is not good. Causes the crank to spl...   Aug 18 2018, 06:45 AM
second wind   This is the second time I have changed the oil and...   Aug 18 2018, 08:49 AM
second wind   I just checked the dip stick tube.....it is bolted...   Aug 18 2018, 09:14 AM
second wind   Ok.....I believe I am eight quarts in but at least...   Aug 18 2018, 09:29 PM
michael7810   I checked my records and I added 6.25 Qts on my la...   Aug 19 2018, 05:55 AM
Rob-O   Not sure what brand oil you’re putting in, but i...   Aug 19 2018, 06:53 AM
second wind   Not sure what brand oil you’re putting in, but ...   Aug 19 2018, 11:43 AM
Beebo Kanelle   Drain it. Measure the volume. See if there...   Aug 19 2018, 09:01 AM
rgalla9146   I'm sure you would have mentioned it but.........   Aug 19 2018, 09:28 AM
second wind   Ok....all done....final post on this...for now of ...   Aug 19 2018, 09:42 PM
michael7810   Ok....all done....final post on this...for now of...   Aug 20 2018, 10:58 AM
whitetwinturbo   .....watch out for checking oil when car is not le...   Aug 20 2018, 09:42 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:48 PM
