| VaccaRabite |
Aug 12 2018, 07:07 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,878 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Waiting on the side of the road for a flatbed to take me home.
Engine ran great. Charging system not so much. Driving along. Lights started going dim. Car started bucking. Only 5 miles to home but it wasn’t going to make it, and no shoulders to pull over safe on the little farm roads. So I pulled into a spot I knew of and shut it down and parked it and now I wait. McMark had said earlier he wasn’t sure about the charging system. But the alt light was not on and no issues before now. So. What’s the alternator I need to buy? Maybe a new VR as well? I guess I should test the battery and make sure it’s okay too. Zach |
| Robnxious |
Aug 20 2018, 08:01 PM
RobnxiousOne ![]() ![]() Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
I just got done running this issue down as well myself. While the Alt light would go out when I started the car and revved it, and it SEEMED like it was charging, it wasn't until I replaced my VR that I was able to get the alternator to start correctly charging the battery. I ended up getting a Hella replacement, which is a bit smaller, though it doesn't look like this
https://www.amazon.com/gp/product/B01LT7E5R...=UTF8&psc=1 |
Vacca Rabite The alternator replacement thread Aug 12 2018, 07:07 PM
FL 000 That sucks, I know the feeling. Same thing happene... Aug 12 2018, 07:26 PM
ClayPerrine Did you check the generator light bulb? The wrong... Aug 12 2018, 07:32 PM
Vacca Rabite Bruce Stone is the man and has an alternator for m... Aug 12 2018, 07:57 PM
bdstone914
Bruce Stone is the man and has an alternator for ... Aug 12 2018, 10:50 PM
bobboinski
Did you check the generator light bulb? The wron... Aug 12 2018, 07:58 PM
ClayPerrine
Did you check the generator light bulb? The wro... Aug 12 2018, 08:06 PM
Mark Henry :agree:
The alternator idiot light was on when you... Aug 12 2018, 08:25 PM
Vacca Rabite Yup. Red light was on when I turned the key and we... Aug 12 2018, 08:30 PM
Mark Henry
Yup. Red light was on when I turned the key and w... Aug 12 2018, 08:43 PM
Unobtanium-inc I hate the site of a pretty Porsche being dragged,... Aug 12 2018, 08:31 PM
Vacca Rabite
I probably would have made it home if I had not... Aug 12 2018, 08:39 PM
bobboinski
Yup. Red light was on when I turned the key and ... Aug 12 2018, 08:50 PM
r_towle get an amp gauge.
Bummer, but you are so close ma... Aug 12 2018, 09:03 PM
Spoke I wouldn't put in a new alternator until you k... Aug 12 2018, 09:04 PM
Amphicar770
I wouldn't put in a new alternator until you ... Aug 13 2018, 06:09 AM
Unobtanium-inc
Ouch! If you drive older cars, AAA Platinum... Aug 13 2018, 06:47 AM
bdstone914
I wouldn't put in a new alternator until you ... Aug 13 2018, 08:10 AM
Dave_Darling I had a VR that came unplugged while I was driving... Aug 12 2018, 10:46 PM
dr914@autoatlanta.com yup you ran out of juice, would check the belt tig... Aug 13 2018, 06:58 AM
Vacca Rabite I have AAA gold so my tow was covered. As I gain c... Aug 13 2018, 08:19 AM
1adam12
I have AAA gold so my tow was covered. As I gain ... Aug 13 2018, 11:26 AM
mepstein I hope the house is ok. We had flooding in SE PA. ... Aug 13 2018, 08:34 AM
Vacca Rabite
I hope the house is ok. We had flooding in SE PA.... Aug 13 2018, 09:12 AM
Vacca Rabite Just did Spokes test of shorting DF and D+.
Batte... Aug 13 2018, 09:09 AM
ClayPerrine
Batt... Aug 13 2018, 12:16 PM
Vacca Rabite
A Bosch alternator is a B circuit alternator. ... Aug 13 2018, 12:37 PM
ClayPerrine
A Bosch alternator is a B circuit alternator. ... Aug 13 2018, 12:45 PM
Vacca Rabite Electrician for the house will be here in a few mi... Aug 13 2018, 11:39 AM
914_teener So was a battery charger plugged in and hooked up ... Aug 13 2018, 12:27 PM
Vacca Rabite
So was a battery charger plugged in and hooked up... Aug 13 2018, 12:31 PM
Vacca Rabite So, new alt, VR and harness are all on order.
Hop... Aug 14 2018, 07:32 AM
90quattrocoupe Nothing to do with the car, but if your GFI plug g... Aug 14 2018, 11:21 AM
914_teener Check the ignition switch. Aug 14 2018, 12:34 PM
Vacca Rabite Tonight I put the new alternator, harness and VR i... Aug 18 2018, 07:59 PM
Spoke 12.89V at idle after the engine is warmed up or ri... Aug 18 2018, 08:08 PM
Vacca Rabite
12.89V at idle after the engine is warmed up or r... Aug 18 2018, 08:10 PM
Spoke It sounds ok so far. How many times did you rev th... Aug 18 2018, 08:48 PM
Vacca Rabite System still isn’t charging right.
I drove the ... Aug 20 2018, 04:07 PM
MarkV A fully charged car battery should be 12.6 volts s... Aug 20 2018, 05:04 PM
904svo Made sure you have the correct bulb (not a led ) i... Aug 20 2018, 05:05 PM
Vacca Rabite
Made sure you have the correct bulb (not a led ) ... Aug 20 2018, 06:16 PM
MarkV Years ago when I thought my mechanical VR was goin... Aug 20 2018, 10:33 PM
MarkV Adjustable:
https://www.ebay.com/itm/NEW-ALTERNAT... Aug 20 2018, 10:36 PM
Vacca Rabite I bought one of the solid state pig-tailed voltage... Aug 21 2018, 07:10 AM
plas76targa Zach, This issue was the first ‘problem’ i exp... Aug 21 2018, 08:29 AM
Vacca Rabite Well, the new solid state VR did nothing.
I am for... Aug 22 2018, 04:44 PM
I am fo... Aug 22 2018, 08:33 PM
Vacca Rabite
If you need another board, just pm me your addres... Aug 22 2018, 09:36 PM
904svo With the engine running measure for voltage betwee... Aug 22 2018, 06:52 PM
Spoke While you have the relay board out, measure the re... Aug 22 2018, 07:54 PM
Vacca Rabite
While you have the relay board out, measure the r... Aug 22 2018, 09:34 PM
Spoke
I did in fact powder coat the shroud and tins. Th... Aug 23 2018, 04:42 AM
Vacca Rabite I got Epstien's package in the mail today. So... Aug 27 2018, 05:04 PM
Spoke one ohm resistance from the alternator case to the... Aug 28 2018, 04:53 AM
Vacca Rabite EVERYTHING seems to be pointing to the voltage reg... Aug 27 2018, 05:09 PM
MarkV Well I am stumped. :confused:
Idle at 12.6 vol... Aug 27 2018, 07:57 PM
904svo just a WAG try cleaning fuse #9 (both sides) this ... Aug 27 2018, 09:40 PM
McMark I can't remember...
Is your alternator harnes... Aug 28 2018, 05:16 AM
Vacca Rabite
I can't remember...
Is your alternator harne... Aug 28 2018, 07:35 AM
jarodswordmaster
I can't remember...
Is your alternator harn... Sep 5 2018, 05:56 AM
VaccaRabite
[quote name='Vacca Rabite' post='2643317' date='A... Sep 5 2018, 06:37 AM
VaccaRabite I got a new battery.
Not really any change over t... Sep 7 2018, 02:14 PM
rjames Watching this thread rabidly as my charging system... Sep 7 2018, 02:48 PM
worn
Not really any change over ... Sep 7 2018, 04:26 PM
Spoke
Not really any change over ... Sep 7 2018, 09:50 PM
FourBlades Does the charging problem only happen when the lig... Sep 7 2018, 07:36 PM
jarodswordmaster I can't get any charge out of my alternator wi... Sep 7 2018, 09:26 PM
Spoke
I can't get any charge out of my alternator w... Sep 7 2018, 09:58 PM
jarodswordmaster
I can't get any charge out of my alternator ... Sep 8 2018, 08:41 AM
Spoke
[quote name='Spoke' post='2646638' date='Sep 7 20... Sep 8 2018, 08:48 AM
jarodswordmaster
[quote name='Spoke' post='2646638' date='Sep 7 2... Sep 8 2018, 08:59 AM
VaccaRabite I’m back to grounds.
And I’m going to put a n... Sep 8 2018, 03:06 PM
Spoke
And I’m going to put a ... Sep 8 2018, 04:13 PM
VaccaRabite Goddamn happy dance.
14 volts at idle.
14 volts ... Sep 8 2018, 05:17 PM
Spoke
14 volts at idle.
14 volts... Sep 8 2018, 10:06 PM
ClayPerrine
14 volts at idle.
14 volts... Sep 9 2018, 05:34 AM
bdstone914 Zach,
Are your alternator mounting brackets pain... Sep 9 2018, 08:53 AM
VaccaRabite
Zach,
Are your alternator mounting brackets pai... Sep 9 2018, 02:50 PM
Spoke
Damn, that was a tough one. Still don’t know wh... Sep 9 2018, 11:26 AM
VaccaRabite
I took apart an engine once and the alternator h... Sep 9 2018, 03:41 PM
worn
14 volts at idle.
14 volts... Sep 9 2018, 06:56 PM
VaccaRabite I’m going to put the race battery back in and ch... Sep 8 2018, 05:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th June 2026 - 04:32 AM |
