| jjs3rd914 |
Aug 22 2018, 09:07 AM
Member ![]() ![]() Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Finishing a 2056 build with new 2L head castings, new WebCam cam, etc. Valve geometry done and SAT, so have custom lenght new Chrome Moly push rods. From all the searches it seems the consensus is zero valve clearance with these push rods and we also installed new genuine 911 swivel feet adjusters.
Can we get a general consensus to confirm ZERO running valve clearance is preferred? or IF not what is the recommended clearance? Thanks jjs3rd914 |
| Jetsetsurfshop |
Aug 22 2018, 05:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Isn't there a requirement from Webcam for the valve lash?
(IMG:style_emoticons/default/poke.gif) |
| VaccaRabite |
Aug 22 2018, 09:45 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,906 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Yes. But that’s intended for stock aluminum pushrods. They heat up and expand and will keep valves from closing all the way. |
jjs3rd914 Valve clearance with Chrome Moly Pushrods Aug 22 2018, 09:07 AM
76-914 "0" clearance :beer2: Aug 22 2018, 09:13 AM
ClayPerrine Adjust the valves so that you can turn the swivel ... Aug 22 2018, 10:51 AM
Vacca Rabite What they said.
Set it to zero. No feeler gauge. ... Aug 22 2018, 10:53 AM
Mark Henry :agree: Zero,
The big thing to watch for is once ... Aug 22 2018, 11:29 AM
worn
:agree: Zero,
The big thing to watch for is once... Aug 22 2018, 01:20 PM
Mark Henry
:agree: Zero,
The big thing to watch for is onc... Aug 22 2018, 02:28 PM
cuddy_k Yep. Someone once called it “loose zero” which... Aug 22 2018, 12:42 PM
jjs3rd914
Yep. Someone once called it “loose zero” whic... Aug 22 2018, 01:16 PM
jtprettyman
Yep. Someone once called it “loose zero” whic... Aug 22 2018, 03:42 PM
bbrock So how does the noise compare between aluminum PRs... Aug 22 2018, 03:30 PM
Mark Henry
So how does the noise compare between aluminum PR... Aug 22 2018, 04:11 PM
euro911 Another term often used is 'zero lash' Aug 23 2018, 12:24 AM
Jetsetsurfshop Anyone have a picture of the camshaft after runnin... Aug 24 2018, 10:15 AM
HAM Inc
Anyone have a picture of the camshaft after runni... Aug 24 2018, 11:53 AM
euro911 Read this: https://www.dragzine.com/tech-stories/h... Aug 24 2018, 11:05 AM
Jetsetsurfshop I found a picture of my camshaft. Its just over a ... Aug 24 2018, 12:20 PM
euro911 That could depend on a few factors ...
What did ... Aug 24 2018, 12:52 PM
ClayPerrine The only time you should run 0 lash is when you ru... Aug 24 2018, 01:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th September 2026 - 09:21 PM |
