> Valve clearance with Chrome Moly Pushrods, Please confirm the clearance is to be ZERO
jjs3rd914
post Aug 22 2018, 09:07 AM
Finishing a 2056 build with new 2L head castings, new WebCam cam, etc. Valve geometry done and SAT, so have custom lenght new Chrome Moly push rods. From all the searches it seems the consensus is zero valve clearance with these push rods and we also installed new genuine 911 swivel feet adjusters.
Can we get a general consensus to confirm ZERO running valve clearance is preferred?
or
IF not what is the recommended clearance?
Thanks
jjs3rd914
ClayPerrine
post Aug 24 2018, 01:07 PM
The only time you should run 0 lash is when you run steel pushrods. The expansion rate on steel pushrods is the same as the cylinders, so they don't tighten up as they get hot.
When running the stock aluminum pushrods, you need to run factory valve lash settings. It accounts for the fact that aluminum expands more than steel when heated, so when your engine running aluminum pushrods is hot, it is at 0 lash. That's why you have to set the valve when the engine is dead cold.
jjs3rd914   Valve clearance with Chrome Moly Pushrods   Aug 22 2018, 09:07 AM
76-914   "0" clearance :beer2:   Aug 22 2018, 09:13 AM
ClayPerrine   Adjust the valves so that you can turn the swivel ...   Aug 22 2018, 10:51 AM
Vacca Rabite   What they said. Set it to zero. No feeler gauge. ...   Aug 22 2018, 10:53 AM
Mark Henry   :agree: Zero, The big thing to watch for is once ...   Aug 22 2018, 11:29 AM
worn   :agree: Zero, The big thing to watch for is once...   Aug 22 2018, 01:20 PM
Mark Henry   :agree: Zero, The big thing to watch for is onc...   Aug 22 2018, 02:28 PM
cuddy_k   Yep. Someone once called it “loose zero” which...   Aug 22 2018, 12:42 PM
jjs3rd914   Yep. Someone once called it “loose zero” whic...   Aug 22 2018, 01:16 PM
jtprettyman   Yep. Someone once called it “loose zero” whic...   Aug 22 2018, 03:42 PM
bbrock   So how does the noise compare between aluminum PRs...   Aug 22 2018, 03:30 PM
Mark Henry   So how does the noise compare between aluminum PR...   Aug 22 2018, 04:11 PM
Jetsetsurfshop   Isn't there a requirement from Webcam for the ...   Aug 22 2018, 05:53 PM
Vacca Rabite   Isn't there a requirement from Webcam for the...   Aug 22 2018, 09:45 PM
euro911   Another term often used is 'zero lash'   Aug 23 2018, 12:24 AM
Jetsetsurfshop   Anyone have a picture of the camshaft after runnin...   Aug 24 2018, 10:15 AM
HAM Inc   Anyone have a picture of the camshaft after runni...   Aug 24 2018, 11:53 AM
euro911   Read this: https://www.dragzine.com/tech-stories/h...   Aug 24 2018, 11:05 AM
Jetsetsurfshop   I found a picture of my camshaft. Its just over a ...   Aug 24 2018, 12:20 PM
euro911   That could depend on a few factors ... What did ...   Aug 24 2018, 12:52 PM
ClayPerrine   The only time you should run 0 lash is when you ru...   Aug 24 2018, 01:07 PM
- Lo-Fi Version Time is now: 6th September 2026 - 09:21 PM
