> 1975 914 brake light/turn signal question....with video!, Update: Video added...see latest post
billh1963
post Aug 27 2018, 06:21 PM
Car Hoarder!
Started working on getting Mark's "BB" ready for Okteenerfest and have started sorting a wiring issue. The turn signals weren't working and after replacing the turn signal relay and turn signal switch to no avail I figured it had to be the flasher switch itself. After replacing the switch (thank you Dominic), I know have hazard lights and turn signals. However, I now have the following questions:
1. I have a burned out right turn signal bulb. Will that cause the yellow turn signal indicator light on the tachometer to stay illuminated? (see picture) I don't have a spare at the moment to see if changing it solves the issue. Current;y, it stays on
2. I don't have an owner's manual. What is the other light on the right side of the tachometer (not illuminated)? It does not illuminate
3. I replaced the turn signal relay with the Wehr brand relay. However, I am still getting the buzzing and fast blinking on the brake light that has been attributed to the relay. I have read that the emergency brake handle and/or needing to reset the MC pressure switch will cause the light to illuminate. In my case, the e-brake handle is down so I will try resetting the MC switch tomorrow. Anything else I should take into account that may cause this condition?
Thank you
914Sixer
post Aug 27 2018, 06:41 PM
Yes dash light is a reminder to check bulbs. Other side is the high beam indicator. Make sure the e-brake switch is not stuck on, remove screw and see if it is rusted up. Reset master cylinder.
billh1963   1975 914 brake light/turn signal question....with video!   Aug 27 2018, 06:21 PM
tmc914   For question #2 it looks like the high beam indica...   Aug 27 2018, 06:37 PM
billh1963   For question #2 it looks like the high beam indic...   Aug 27 2018, 06:46 PM
914Sixer   Yes dash light is a reminder to check bulbs. Othe...   Aug 27 2018, 06:41 PM
billh1963   Yes dash light is a reminder to check bulbs. Oth...   Aug 27 2018, 06:48 PM
DRPHIL914   Yes dash light is a reminder to check bulbs. Ot...   Aug 28 2018, 06:47 AM
Rob-O   Yes dash light is a reminder to check bulbs. Ot...   Aug 28 2018, 05:14 AM
Rob-O   Like this. You can use some of the other colors t...   Aug 28 2018, 05:21 AM
Spoke   1. I have a burned out right turn signal bulb. W...   Aug 28 2018, 09:16 AM
billh1963   Cleaned the oxidation off the turn signal bulb and...   Aug 28 2018, 06:52 PM
billh1963   Anyone else experience this?   Aug 29 2018, 04:36 AM
Spoke   It looks like the brake warning light is on consta...   Aug 29 2018, 07:27 AM
theer   Turning on the parking lights (light switch pulle...   Aug 29 2018, 08:41 AM
billh1963   Turning on the parking lights (light switch pull...   Aug 29 2018, 09:01 AM
billh1963   Great drawing! I think you are right, however,...   Aug 29 2018, 08:58 AM
Spoke   Great drawing! I think you are right, however...   Aug 29 2018, 09:21 AM
billh1963   There may be only one brake warning light. The i...   Aug 29 2018, 05:49 PM
DRPHIL914   hope you can get this sorted, is it the last issue...   Aug 29 2018, 09:26 AM
billh1963   hope you can get this sorted, is it the last issu...   Aug 29 2018, 12:58 PM
Spoke   The ebrake wire runs under the front seat and coul...   Aug 29 2018, 06:24 PM
billh1963   The ebrake wire runs under the front seat and cou...   Aug 29 2018, 06:42 PM
Spoke   You should be able to get to the switch w/o removi...   Aug 30 2018, 06:12 AM
billh1963   You should be able to get to the switch w/o remov...   Aug 30 2018, 08:24 AM
tmc914   I am watching this thread with great interest beca...   Aug 30 2018, 08:49 AM
billh1963   I am watching this thread with great interest bec...   Aug 30 2018, 10:56 AM
billh1963   Update: Replaced the e-brake switch and no joy. I ...   Sep 3 2018, 05:59 PM
DRPHIL914   Update: Replaced the e-brake switch and no joy. I...   Sep 4 2018, 08:48 AM
billh1963   Update: Replaced the e-brake switch and no joy. ...   Sep 4 2018, 08:59 AM
- Lo-Fi Version Time is now: 2nd November 2025 - 10:53 PM
