> The alternator replacement thread, Fixed!
VaccaRabite
post Aug 12 2018, 07:07 PM
En Garde!
Waiting on the side of the road for a flatbed to take me home.
Engine ran great. Charging system not so much. Driving along. Lights started going dim. Car started bucking. Only 5 miles to home but it wasn’t going to make it, and no shoulders to pull over safe on the little farm roads. So I pulled into a spot I knew of and shut it down and parked it and now I wait.
McMark had said earlier he wasn’t sure about the charging system. But the alt light was not on and no issues before now.
So. What’s the alternator I need to buy?
Maybe a new VR as well?
I guess I should test the battery and make sure it’s okay too.
Zach
904svo
post Aug 27 2018, 09:40 PM
904SVO
just a WAG try cleaning fuse #9 (both sides) this supply the voltage to excite the
alternator if its dirty it could stop it from charging.
Vacca Rabite   The alternator replacement thread   Aug 12 2018, 07:07 PM
FL 000   That sucks, I know the feeling. Same thing happene...   Aug 12 2018, 07:26 PM
ClayPerrine   Did you check the generator light bulb? The wrong...   Aug 12 2018, 07:32 PM
Vacca Rabite   Bruce Stone is the man and has an alternator for m...   Aug 12 2018, 07:57 PM
bdstone914   Bruce Stone is the man and has an alternator for ...   Aug 12 2018, 10:50 PM
bobboinski   Did you check the generator light bulb? The wron...   Aug 12 2018, 07:58 PM
ClayPerrine   Did you check the generator light bulb? The wro...   Aug 12 2018, 08:06 PM
Mark Henry   :agree: The alternator idiot light was on when you...   Aug 12 2018, 08:25 PM
Vacca Rabite   Yup. Red light was on when I turned the key and we...   Aug 12 2018, 08:30 PM
Mark Henry   Yup. Red light was on when I turned the key and w...   Aug 12 2018, 08:43 PM
Unobtanium-inc   I hate the site of a pretty Porsche being dragged,...   Aug 12 2018, 08:31 PM
Vacca Rabite   I probably would have made it home if I had not...   Aug 12 2018, 08:39 PM
bobboinski   Yup. Red light was on when I turned the key and ...   Aug 12 2018, 08:50 PM
r_towle   get an amp gauge. Bummer, but you are so close ma...   Aug 12 2018, 09:03 PM
Spoke   I wouldn't put in a new alternator until you k...   Aug 12 2018, 09:04 PM
Amphicar770   I wouldn't put in a new alternator until you ...   Aug 13 2018, 06:09 AM
Unobtanium-inc   Ouch! If you drive older cars, AAA Platinum...   Aug 13 2018, 06:47 AM
bdstone914   I wouldn't put in a new alternator until you ...   Aug 13 2018, 08:10 AM
Dave_Darling   I had a VR that came unplugged while I was driving...   Aug 12 2018, 10:46 PM
dr914@autoatlanta.com   yup you ran out of juice, would check the belt tig...   Aug 13 2018, 06:58 AM
Vacca Rabite   I have AAA gold so my tow was covered. As I gain c...   Aug 13 2018, 08:19 AM
1adam12   I have AAA gold so my tow was covered. As I gain ...   Aug 13 2018, 11:26 AM
mepstein   I hope the house is ok. We had flooding in SE PA. ...   Aug 13 2018, 08:34 AM
Vacca Rabite   I hope the house is ok. We had flooding in SE PA....   Aug 13 2018, 09:12 AM
Vacca Rabite   Just did Spokes test of shorting DF and D+. Batte...   Aug 13 2018, 09:09 AM
ClayPerrine   Just did Spokes test of shorting DF and D+. Batt...   Aug 13 2018, 12:16 PM
Vacca Rabite   A Bosch alternator is a B circuit alternator. ...   Aug 13 2018, 12:37 PM
ClayPerrine   A Bosch alternator is a B circuit alternator. ...   Aug 13 2018, 12:45 PM
Vacca Rabite   Electrician for the house will be here in a few mi...   Aug 13 2018, 11:39 AM
914_teener   So was a battery charger plugged in and hooked up ...   Aug 13 2018, 12:27 PM
Vacca Rabite   So was a battery charger plugged in and hooked up...   Aug 13 2018, 12:31 PM
Vacca Rabite   So, new alt, VR and harness are all on order. Hop...   Aug 14 2018, 07:32 AM
90quattrocoupe   Nothing to do with the car, but if your GFI plug g...   Aug 14 2018, 11:21 AM
914_teener   Check the ignition switch.   Aug 14 2018, 12:34 PM
Vacca Rabite   Tonight I put the new alternator, harness and VR i...   Aug 18 2018, 07:59 PM
Spoke   12.89V at idle after the engine is warmed up or ri...   Aug 18 2018, 08:08 PM
Vacca Rabite   12.89V at idle after the engine is warmed up or r...   Aug 18 2018, 08:10 PM
Spoke   It sounds ok so far. How many times did you rev th...   Aug 18 2018, 08:48 PM
Vacca Rabite   System still isn’t charging right. I drove the ...   Aug 20 2018, 04:07 PM
MarkV   A fully charged car battery should be 12.6 volts s...   Aug 20 2018, 05:04 PM
904svo   Made sure you have the correct bulb (not a led ) i...   Aug 20 2018, 05:05 PM
Vacca Rabite   Made sure you have the correct bulb (not a led ) ...   Aug 20 2018, 06:16 PM
Robnxious   I just got done running this issue down as well my...   Aug 20 2018, 08:01 PM
MarkV   Years ago when I thought my mechanical VR was goin...   Aug 20 2018, 10:33 PM
MarkV   Adjustable: https://www.ebay.com/itm/NEW-ALTERNAT...   Aug 20 2018, 10:36 PM
Vacca Rabite   I bought one of the solid state pig-tailed voltage...   Aug 21 2018, 07:10 AM
plas76targa   Zach, This issue was the first ‘problem’ i exp...   Aug 21 2018, 08:29 AM
Vacca Rabite   Well, the new solid state VR did nothing. I am for...   Aug 22 2018, 04:44 PM
mepstein   Well, the new solid state VR did nothing. I am fo...   Aug 22 2018, 08:33 PM
Vacca Rabite   If you need another board, just pm me your addres...   Aug 22 2018, 09:36 PM
904svo   With the engine running measure for voltage betwee...   Aug 22 2018, 06:52 PM
Spoke   While you have the relay board out, measure the re...   Aug 22 2018, 07:54 PM
Vacca Rabite   While you have the relay board out, measure the r...   Aug 22 2018, 09:34 PM
Spoke   I did in fact powder coat the shroud and tins. Th...   Aug 23 2018, 04:42 AM
Vacca Rabite   I got Epstien's package in the mail today. So...   Aug 27 2018, 05:04 PM
Spoke   one ohm resistance from the alternator case to the...   Aug 28 2018, 04:53 AM
Vacca Rabite   EVERYTHING seems to be pointing to the voltage reg...   Aug 27 2018, 05:09 PM
MarkV   Well I am stumped. :confused: Idle at 12.6 vol...   Aug 27 2018, 07:57 PM
904svo   just a WAG try cleaning fuse #9 (both sides) this ...   Aug 27 2018, 09:40 PM
McMark   I can't remember... Is your alternator harnes...   Aug 28 2018, 05:16 AM
Vacca Rabite   I can't remember... Is your alternator harne...   Aug 28 2018, 07:35 AM
jarodswordmaster   I can't remember... Is your alternator harn...   Sep 5 2018, 05:56 AM
VaccaRabite   [quote name='Vacca Rabite' post='2643317' date='A...   Sep 5 2018, 06:37 AM
VaccaRabite   I got a new battery. Not really any change over t...   Sep 7 2018, 02:14 PM
rjames   Watching this thread rabidly as my charging system...   Sep 7 2018, 02:48 PM
worn   I got a new battery. Not really any change over ...   Sep 7 2018, 04:26 PM
Spoke   I got a new battery. Not really any change over ...   Sep 7 2018, 09:50 PM
FourBlades   Does the charging problem only happen when the lig...   Sep 7 2018, 07:36 PM
jarodswordmaster   I can't get any charge out of my alternator wi...   Sep 7 2018, 09:26 PM
Spoke   I can't get any charge out of my alternator w...   Sep 7 2018, 09:58 PM
jarodswordmaster   I can't get any charge out of my alternator ...   Sep 8 2018, 08:41 AM
Spoke   [quote name='Spoke' post='2646638' date='Sep 7 20...   Sep 8 2018, 08:48 AM
jarodswordmaster   [quote name='Spoke' post='2646638' date='Sep 7 2...   Sep 8 2018, 08:59 AM
VaccaRabite   I’m back to grounds. And I’m going to put a n...   Sep 8 2018, 03:06 PM
Spoke   I’m back to grounds. And I’m going to put a ...   Sep 8 2018, 04:13 PM
VaccaRabite   Goddamn happy dance. 14 volts at idle. 14 volts ...   Sep 8 2018, 05:17 PM
Spoke   Goddamn happy dance. 14 volts at idle. 14 volts...   Sep 8 2018, 10:06 PM
ClayPerrine   Goddamn happy dance. 14 volts at idle. 14 volts...   Sep 9 2018, 05:34 AM
bdstone914   Zach, Are your alternator mounting brackets pain...   Sep 9 2018, 08:53 AM
VaccaRabite   Zach, Are your alternator mounting brackets pai...   Sep 9 2018, 02:50 PM
Spoke   Damn, that was a tough one. Still don’t know wh...   Sep 9 2018, 11:26 AM
VaccaRabite   I took apart an engine once and the alternator h...   Sep 9 2018, 03:41 PM
worn   Goddamn happy dance. 14 volts at idle. 14 volts...   Sep 9 2018, 06:56 PM
VaccaRabite   I’m going to put the race battery back in and ch...   Sep 8 2018, 05:20 PM
- Lo-Fi Version Time is now: 6th June 2026 - 04:33 AM
