> 1975 914 brake light/turn signal question....with video!, Update: Video added...see latest post
billh1963
post Aug 27 2018, 06:21 PM
Car Hoarder!
Started working on getting Mark's "BB" ready for Okteenerfest and have started sorting a wiring issue. The turn signals weren't working and after replacing the turn signal relay and turn signal switch to no avail I figured it had to be the flasher switch itself. After replacing the switch (thank you Dominic), I know have hazard lights and turn signals. However, I now have the following questions:
1. I have a burned out right turn signal bulb. Will that cause the yellow turn signal indicator light on the tachometer to stay illuminated? (see picture) I don't have a spare at the moment to see if changing it solves the issue. Current;y, it stays on
2. I don't have an owner's manual. What is the other light on the right side of the tachometer (not illuminated)? It does not illuminate
3. I replaced the turn signal relay with the Wehr brand relay. However, I am still getting the buzzing and fast blinking on the brake light that has been attributed to the relay. I have read that the emergency brake handle and/or needing to reset the MC pressure switch will cause the light to illuminate. In my case, the e-brake handle is down so I will try resetting the MC switch tomorrow. Anything else I should take into account that may cause this condition?
Thank you
914Sixer
post Aug 27 2018, 06:41 PM
Yes dash light is a reminder to check bulbs. Other side is the high beam indicator. Make sure the e-brake switch is not stuck on, remove screw and see if it is rusted up. Reset master cylinder.
billh1963
post Aug 27 2018, 06:48 PM
Car Hoarder!
QUOTE(914Sixer @ Aug 27 2018, 08:41 PM) *
I'll check the ebrake switch. Didn't think about it being stuck on. If the switch is missing or damaged would the light be on or off?
DRPHIL914
post Aug 28 2018, 06:47 AM
Dr. Phil
QUOTE(billh1963 @ Aug 27 2018, 08:48 PM) *
not sure but I think my switch didn't work when I first got my car and it was off, not on.
billh1963   1975 914 brake light/turn signal question....with video!   Aug 27 2018, 06:21 PM
tmc914   For question #2 it looks like the high beam indica...   Aug 27 2018, 06:37 PM
billh1963   For question #2 it looks like the high beam indic...   Aug 27 2018, 06:46 PM
914Sixer   Yes dash light is a reminder to check bulbs. Othe...   Aug 27 2018, 06:41 PM
billh1963   Yes dash light is a reminder to check bulbs. Oth...   Aug 27 2018, 06:48 PM
DRPHIL914   Yes dash light is a reminder to check bulbs. Ot...   Aug 28 2018, 06:47 AM
Rob-O   Yes dash light is a reminder to check bulbs. Ot...   Aug 28 2018, 05:14 AM
Rob-O   Like this. You can use some of the other colors t...   Aug 28 2018, 05:21 AM
Spoke   1. I have a burned out right turn signal bulb. W...   Aug 28 2018, 09:16 AM
billh1963   Cleaned the oxidation off the turn signal bulb and...   Aug 28 2018, 06:52 PM
billh1963   Anyone else experience this?   Aug 29 2018, 04:36 AM
Spoke   It looks like the brake warning light is on consta...   Aug 29 2018, 07:27 AM
theer   Turning on the parking lights (light switch pulle...   Aug 29 2018, 08:41 AM
billh1963   Turning on the parking lights (light switch pull...   Aug 29 2018, 09:01 AM
billh1963   Great drawing! I think you are right, however,...   Aug 29 2018, 08:58 AM
Spoke   Great drawing! I think you are right, however...   Aug 29 2018, 09:21 AM
billh1963   There may be only one brake warning light. The i...   Aug 29 2018, 05:49 PM
DRPHIL914   hope you can get this sorted, is it the last issue...   Aug 29 2018, 09:26 AM
billh1963   hope you can get this sorted, is it the last issu...   Aug 29 2018, 12:58 PM
Spoke   The ebrake wire runs under the front seat and coul...   Aug 29 2018, 06:24 PM
billh1963   The ebrake wire runs under the front seat and cou...   Aug 29 2018, 06:42 PM
Spoke   You should be able to get to the switch w/o removi...   Aug 30 2018, 06:12 AM
billh1963   You should be able to get to the switch w/o remov...   Aug 30 2018, 08:24 AM
tmc914   I am watching this thread with great interest beca...   Aug 30 2018, 08:49 AM
billh1963   I am watching this thread with great interest bec...   Aug 30 2018, 10:56 AM
billh1963   Update: Replaced the e-brake switch and no joy. I ...   Sep 3 2018, 05:59 PM
DRPHIL914   Update: Replaced the e-brake switch and no joy. I...   Sep 4 2018, 08:48 AM
billh1963   Update: Replaced the e-brake switch and no joy. ...   Sep 4 2018, 08:59 AM
- Lo-Fi Version Time is now: 2nd November 2025 - 10:53 PM
