| billh1963 |
Aug 27 2018, 06:21 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,410 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Started working on getting Mark's "BB" ready for Okteenerfest and have started sorting a wiring issue. The turn signals weren't working and after replacing the turn signal relay and turn signal switch to no avail I figured it had to be the flasher switch itself. After replacing the switch (thank you Dominic), I know have hazard lights and turn signals. However, I now have the following questions:
1. I have a burned out right turn signal bulb. Will that cause the yellow turn signal indicator light on the tachometer to stay illuminated? (see picture) I don't have a spare at the moment to see if changing it solves the issue. Current;y, it stays on 2. I don't have an owner's manual. What is the other light on the right side of the tachometer (not illuminated)? It does not illuminate 3. I replaced the turn signal relay with the Wehr brand relay. However, I am still getting the buzzing and fast blinking on the brake light that has been attributed to the relay. I have read that the emergency brake handle and/or needing to reset the MC pressure switch will cause the light to illuminate. In my case, the e-brake handle is down so I will try resetting the MC switch tomorrow. Anything else I should take into account that may cause this condition? Thank you ![]() |
| Spoke |
Aug 30 2018, 06:12 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,264 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
You should be able to get to the switch w/o removing the seat. Mostly the ebrake handle is in the way.
| billh1963 |
Aug 30 2018, 08:24 AM
billh1963 1975 914 brake light/turn signal question....with video! Aug 27 2018, 06:21 PM
tmc914 For question #2 it looks like the high beam indica... Aug 27 2018, 06:37 PM
billh1963
For question #2 it looks like the high beam indic... Aug 27 2018, 06:46 PM
914Sixer Yes dash light is a reminder to check bulbs. Othe... Aug 27 2018, 06:41 PM
billh1963
Yes dash light is a reminder to check bulbs. Oth... Aug 27 2018, 06:48 PM
DRPHIL914
Yes dash light is a reminder to check bulbs. Ot... Aug 28 2018, 06:47 AM
Rob-O
Yes dash light is a reminder to check bulbs. Ot... Aug 28 2018, 05:14 AM
Rob-O Like this.
You can use some of the other colors t... Aug 28 2018, 05:21 AM
Spoke
1. I have a burned out right turn signal bulb. W... Aug 28 2018, 09:16 AM
billh1963 Cleaned the oxidation off the turn signal bulb and... Aug 28 2018, 06:52 PM
billh1963 Anyone else experience this? Aug 29 2018, 04:36 AM
Spoke It looks like the brake warning light is on consta... Aug 29 2018, 07:27 AM
theer
Turning on the parking lights (light switch pulle... Aug 29 2018, 08:41 AM
billh1963
Turning on the parking lights (light switch pull... Aug 29 2018, 09:01 AM
billh1963 Great drawing! I think you are right, however,... Aug 29 2018, 08:58 AM
Spoke
Great drawing! I think you are right, however... Aug 29 2018, 09:21 AM
billh1963
There may be only one brake warning light. The i... Aug 29 2018, 05:49 PM
DRPHIL914 hope you can get this sorted, is it the last issue... Aug 29 2018, 09:26 AM
billh1963
hope you can get this sorted, is it the last issu... Aug 29 2018, 12:58 PM
Spoke The ebrake wire runs under the front seat and coul... Aug 29 2018, 06:24 PM
billh1963
The ebrake wire runs under the front seat and cou... Aug 29 2018, 06:42 PM
tmc914 I am watching this thread with great interest beca... Aug 30 2018, 08:49 AM
billh1963
I am watching this thread with great interest bec... Aug 30 2018, 10:56 AM
billh1963 Update: Replaced the e-brake switch and no joy. I ... Sep 3 2018, 05:59 PM
DRPHIL914
Update: Replaced the e-brake switch and no joy. I... Sep 4 2018, 08:48 AM
billh1963
Update: Replaced the e-brake switch and no joy. ... Sep 4 2018, 08:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2025 - 10:53 PM |
