| billh1963 |
Aug 27 2018, 06:21 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,410 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Started working on getting Mark's "BB" ready for Okteenerfest and have started sorting a wiring issue. The turn signals weren't working and after replacing the turn signal relay and turn signal switch to no avail I figured it had to be the flasher switch itself. After replacing the switch (thank you Dominic), I know have hazard lights and turn signals. However, I now have the following questions:
1. I have a burned out right turn signal bulb. Will that cause the yellow turn signal indicator light on the tachometer to stay illuminated? (see picture) I don't have a spare at the moment to see if changing it solves the issue. Current;y, it stays on 2. I don't have an owner's manual. What is the other light on the right side of the tachometer (not illuminated)? It does not illuminate 3. I replaced the turn signal relay with the Wehr brand relay. However, I am still getting the buzzing and fast blinking on the brake light that has been attributed to the relay. I have read that the emergency brake handle and/or needing to reset the MC pressure switch will cause the light to illuminate. In my case, the e-brake handle is down so I will try resetting the MC switch tomorrow. Anything else I should take into account that may cause this condition? Thank you ![]() |
| tmc914 |
Aug 30 2018, 08:49 AM
Member ![]() ![]() Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States
I am watching this thread with great interest because I have a similar but not exactly the same problem. Mine started when the indicator lamp was changed for the e-brake. Now my relay flashes crazy like yours but I have a 1973 with two blinker indicators. Plan on changing most of the indicator lamps to LED soon. Maybe that will help.
It looks like your Tach and maybe speedometer lamps have been upgraded to LED's from the video. The fuel light looks original. The seat is easy to remove but on my '73 there is a catch tab so when you pull the seat all the way forward it does not pop out of the track. You have to reach under the seat and push up on a tab inside the track (can't remember what side) and get fingers full of grease doing it. |
billh1963 1975 914 brake light/turn signal question....with video! Aug 27 2018, 06:21 PM
tmc914 For question #2 it looks like the high beam indica... Aug 27 2018, 06:37 PM
billh1963
For question #2 it looks like the high beam indic... Aug 27 2018, 06:46 PM
914Sixer Yes dash light is a reminder to check bulbs. Othe... Aug 27 2018, 06:41 PM
billh1963
Yes dash light is a reminder to check bulbs. Oth... Aug 27 2018, 06:48 PM
DRPHIL914
Yes dash light is a reminder to check bulbs. Ot... Aug 28 2018, 06:47 AM
Rob-O
Yes dash light is a reminder to check bulbs. Ot... Aug 28 2018, 05:14 AM
Rob-O Like this.
You can use some of the other colors t... Aug 28 2018, 05:21 AM
Spoke
1. I have a burned out right turn signal bulb. W... Aug 28 2018, 09:16 AM
billh1963 Cleaned the oxidation off the turn signal bulb and... Aug 28 2018, 06:52 PM
billh1963 Anyone else experience this? Aug 29 2018, 04:36 AM
Spoke It looks like the brake warning light is on consta... Aug 29 2018, 07:27 AM
theer
Turning on the parking lights (light switch pulle... Aug 29 2018, 08:41 AM
billh1963
Turning on the parking lights (light switch pull... Aug 29 2018, 09:01 AM
billh1963 Great drawing! I think you are right, however,... Aug 29 2018, 08:58 AM
Spoke
Great drawing! I think you are right, however... Aug 29 2018, 09:21 AM
billh1963
There may be only one brake warning light. The i... Aug 29 2018, 05:49 PM
DRPHIL914 hope you can get this sorted, is it the last issue... Aug 29 2018, 09:26 AM
billh1963
hope you can get this sorted, is it the last issu... Aug 29 2018, 12:58 PM
Spoke The ebrake wire runs under the front seat and coul... Aug 29 2018, 06:24 PM
billh1963
The ebrake wire runs under the front seat and cou... Aug 29 2018, 06:42 PM
Spoke You should be able to get to the switch w/o removi... Aug 30 2018, 06:12 AM
billh1963
You should be able to get to the switch w/o remov... Aug 30 2018, 08:24 AM
billh1963
I am watching this thread with great interest bec... Aug 30 2018, 10:56 AM
billh1963 Update: Replaced the e-brake switch and no joy. I ... Sep 3 2018, 05:59 PM
DRPHIL914
Update: Replaced the e-brake switch and no joy. I... Sep 4 2018, 08:48 AM
billh1963
Update: Replaced the e-brake switch and no joy. ... Sep 4 2018, 08:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2025 - 10:53 PM |
