| mepstein |
Sep 2 2018, 03:10 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
What can go wrong? (IMG:style_emoticons/default/confused24.gif)
(IMG:style_emoticons/default/biggrin.gif) Attached image(s)
| mb911 |
Sep 3 2018, 12:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,729 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I wonder if I should do some welding youtube video's to share with all of you.
| mepstein |
Sep 3 2018, 12:42 PM
I wonder if I should do some welding youtube video's to share with all of you. Absolutely! I haven’t looked at a lot of YouTube welding videos yet but what I have seen is a lot of demo on angle iron. It would be nice to see some with 18 gauge like our cars. Lap weld, butt, etc. Also, it’s hard to see what the motion is when they are welding. It looks like a slight side to side movement as they move down the weld. If that’s the case, It would be great to see what you are doing just using a pencil and paper. I need basic instruction but I’d really just like to learn the right way to do it from someone I trust that knows what they are doing rather than trying to figure it out from the self proclaimed internet pros. |
| mgp4591 |
Sep 3 2018, 02:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,908 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I wonder if I should do some welding youtube video's to share with all of you. Absolutely! I haven’t looked at a lot of YouTube welding videos yet but what I have seen is a lot of demo on angle iron. It would be nice to see some with 18 gauge like our cars. Lap weld, butt, etc. Also, it’s hard to see what the motion is when they are welding. It looks like a slight side to side movement as they move down the weld. If that’s the case, It would be great to see what you are doing just using a pencil and paper. I need basic instruction but I’d really just like to learn the right way to do it from someone I trust that knows what they are doing rather than trying to figure it out from the self proclaimed internet pros. I use a slight back and forth with a wrist twist or for larger patterns a small circular swirl while progressing down your path. Practice this on your test material with the heat all the way up and enough feed to keep the material fill going. Once you get it with full power, then you can back off to adjust for the thickness of your intended work. Ideally it should sound like frying bacon without the smell... hmmm.... maybe my next invention.... (IMG:style_emoticons/default/idea.gif) |
| mb911 |
Sep 3 2018, 04:03 PM
I wonder if I should do some welding youtube video's to share with all of you. Absolutely! I haven’t looked at a lot of YouTube welding videos yet but what I have seen is a lot of demo on angle iron. It would be nice to see some with 18 gauge like our cars. Lap weld, butt, etc. Also, it’s hard to see what the motion is when they are welding. It looks like a slight side to side movement as they move down the weld. If that’s the case, It would be great to see what you are doing just using a pencil and paper. I need basic instruction but I’d really just like to learn the right way to do it from someone I trust that knows what they are doing rather than trying to figure it out from the self proclaimed internet pros. I use a slight back and forth with a wrist twist or for larger patterns a small circular swirl while progressing down your path. Practice this on your test material with the heat all the way up and enough feed to keep the material fill going. Once you get it with full power, then you can back off to adjust for the thickness of your intended work. Ideally it should sound like frying bacon without the smell... hmmm.... maybe my next invention.... (IMG:style_emoticons/default/idea.gif) Interestingly enough in production/industrial robot's there typically is straight line welds with no weaving or techniques used. Just proper voltage (potential amperage) and wire speed (actual amperage). On that note it is extremely important that people under stand that Amperage = heat in the welding world. In GMAW /MIG that is wire speed. My analogy is pretty simple. In a car with manual transmission each gear gives you potential speed from low to high but what makes it go is the gas pedal. So if you consider each gear a potential range then understand that voltage is = a gear range and wire speed is = amperage within that potential range. They have to work together. Also note that voltage does not = heat.. That is the biggest misunderstanding when it comes to MIG and often weld failures come from that misunderstanding. |
mepstein Mark’s misadventures Sep 2 2018, 03:10 PM
billh1963 Uh oh....the adventure begins! Sep 2 2018, 03:22 PM
BeatNavy A guy that's been around Porsches that long wi... Sep 2 2018, 04:03 PM
914forme Be safe cause lots can go wrong.
Make sure the f... Sep 2 2018, 04:07 PM
Make sure the ... Sep 2 2018, 04:33 PM
bdstone914
What can go wrong? :confused:
:D
Nothing... Sep 2 2018, 04:15 PM
naro914 Lol...I got a welder moths ago from a buddy that ... Sep 2 2018, 04:42 PM
Lol...I got a welder moths ago from a buddy that... Sep 2 2018, 04:50 PM
914bub
Lol...I got a welder moths ago from a buddy that... Sep 2 2018, 05:39 PM
naro914
Lol...I got a welder moths ago from a buddy tha... Sep 2 2018, 06:28 PM
rhodyguy Long cord. Sep 2 2018, 06:39 PM
Jonathan Livesay
Long cord.
Run some wires to a new plug. Don... Sep 2 2018, 07:26 PM
sholman5 That's what she said. Sep 2 2018, 06:44 PM
JOEPROPER Just takes a little practice. You'll pick it ... Sep 2 2018, 07:02 PM
bbrock Careful... those things can melt steel. :welder: Sep 2 2018, 07:18 PM
gereed75 Got a 110V Hobart Handler back in the spring. It ... Sep 2 2018, 08:42 PM
Jamie
Got a 110V Hobart Handler back in the spring. It... Sep 3 2018, 09:25 AM
IronHillRestorations Make 3 or four 1" beads on some 1/4" ang... Sep 3 2018, 08:18 AM
mb911
I wonder if I should do some welding youtube vid... Sep 3 2018, 02:15 PM
[quote name='mepstein' post='2645105' date='Sep ... Sep 3 2018, 04:43 PM
mb911
[quote name='mb911' post='2645144' date='Sep 3 20... Sep 3 2018, 05:08 PM
[quote name='mb911' post='2645144' date='Sep 3 2... Sep 3 2018, 05:53 PM
I wonder if I should do some welding youtube vide... Sep 3 2018, 01:47 PM
mb911
I wonder if I should do some welding youtube vid... Sep 3 2018, 02:20 PM
gereed75 This is one of the best vids IMHO. https://m.youtu... Sep 3 2018, 01:27 PM
Chris H. This is a decent series:
lzBGZaS1apw
There are s... Sep 3 2018, 03:45 PM
GaroldShaffer If you have time heck with your local community co... Sep 3 2018, 06:14 PM
saigon71
:D
Welcome... Sep 4 2018, 05:37 AM
:D
Welcom... Sep 4 2018, 05:54 AM
falcor75 I had an old Esab 125A Miggy for most of my restor... Sep 4 2018, 05:55 AM
76-914 Holding the tip at the correct distance and angle ... Sep 4 2018, 08:35 AM
IronHillRestorations I took a VoTech class so I could improve my TIG we... Sep 4 2018, 10:36 AM
nihil44 Mepstein (I think your name is Mark - no discourte... Sep 5 2018, 04:03 AM
eyecolor Please have a fire extinguisher nearby.
Don't ... Sep 5 2018, 08:25 PM
Don't... Sep 5 2018, 08:29 PM
davep Some 40 years ago I took a night school course at ... Sep 5 2018, 08:44 PM
r_towle Get a sheet of 18 and 20 gauge.
This is metal caul... Sep 5 2018, 08:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:10 AM |
