> Mark’s misadventures, Just getting started
post Sep 2 2018, 03:10 PM
914-6 GT in waiting
What can go wrong? (IMG:style_emoticons/default/confused24.gif)
mb911
post Sep 3 2018, 12:21 PM
I wonder if I should do some welding youtube video's to share with all of you.
post Sep 3 2018, 12:42 PM
914-6 GT in waiting
QUOTE(mb911 @ Sep 3 2018, 02:21 PM) *
Absolutely!
I haven’t looked at a lot of YouTube welding videos yet but what I have seen is a lot of demo on angle iron. It would be nice to see some with 18 gauge like our cars. Lap weld, butt, etc.
Also, it’s hard to see what the motion is when they are welding. It looks like a slight side to side movement as they move down the weld. If that’s the case, It would be great to see what you are doing just using a pencil and paper.
I need basic instruction but I’d really just like to learn the right way to do it from someone I trust that knows what they are doing rather than trying to figure it out from the self proclaimed internet pros.
mgp4591
post Sep 3 2018, 02:51 PM
QUOTE(mepstein @ Sep 3 2018, 12:42 PM) *
Absolutely!
I use a slight back and forth with a wrist twist or for larger patterns a small circular swirl while progressing down your path. Practice this on your test material with the heat all the way up and enough feed to keep the material fill going. Once you get it with full power, then you can back off to adjust for the thickness of your intended work. Ideally it should sound like frying bacon without the smell... hmmm.... maybe my next invention.... (IMG:style_emoticons/default/idea.gif)
mb911
post Sep 3 2018, 04:03 PM
QUOTE(mgp4591 @ Sep 3 2018, 12:51 PM) *
Absolutely!
Interestingly enough in production/industrial robot's there typically is straight line welds with no weaving or techniques used. Just proper voltage (potential amperage) and wire speed (actual amperage).
On that note it is extremely important that people under stand that Amperage = heat in the welding world. In GMAW /MIG that is wire speed.
My analogy is pretty simple. In a car with manual transmission each gear gives you potential speed from low to high but what makes it go is the gas pedal. So if you consider each gear a potential range then understand that voltage is = a gear range and wire speed is = amperage within that potential range. They have to work together.
Also note that voltage does not = heat.. That is the biggest misunderstanding when it comes to MIG and often weld failures come from that misunderstanding.
post Sep 3 2018, 04:43 PM
914-6 GT in waiting
QUOTE(mb911 @ Sep 3 2018, 06:03 PM) *
Absolutely!
So when you weld on your car, do you weld in a straight line or squiggle back and forth.
mb911
post Sep 3 2018, 05:08 PM
QUOTE(mepstein @ Sep 3 2018, 02:43 PM) *
Absolutely!
For sheet metal for a car like ours no reason to weave or do any pattern. What I do is my own version of a pulse weld. You on the trigger then off then on then off and what that does it creates a series of over lapping tack welds that allow for higher heat settings but allows to cool down thus less warpage .. This is common place in the avation world as well. Takes a little practice to get right. You will see the glow from the weld when on trigger as soon as you let off you will see the glow disapate and then its time to hit the trigger again..
Picture its short 1/8" welds overlapping like a stair case if you will..
mepstein   Mark’s misadventures   Sep 2 2018, 03:10 PM
billh1963   Uh oh....the adventure begins!   Sep 2 2018, 03:22 PM
BeatNavy   A guy that's been around Porsches that long wi...   Sep 2 2018, 04:03 PM
914forme   Be safe cause lots can go wrong. Make sure the f...   Sep 2 2018, 04:07 PM
mepstein   Be safe cause lots can go wrong. Make sure the ...   Sep 2 2018, 04:33 PM
bdstone914   What can go wrong? :confused: :D Nothing...   Sep 2 2018, 04:15 PM
naro914   Lol...I got a welder moths ago from a buddy that ...   Sep 2 2018, 04:42 PM
mepstein   Lol...I got a welder moths ago from a buddy that...   Sep 2 2018, 04:50 PM
914bub   Lol...I got a welder moths ago from a buddy that...   Sep 2 2018, 05:39 PM
naro914   Lol...I got a welder moths ago from a buddy tha...   Sep 2 2018, 06:28 PM
rhodyguy   Long cord.   Sep 2 2018, 06:39 PM
Jonathan Livesay   Long cord. Run some wires to a new plug. Don...   Sep 2 2018, 07:26 PM
sholman5   That's what she said.   Sep 2 2018, 06:44 PM
JOEPROPER   Just takes a little practice. You'll pick it ...   Sep 2 2018, 07:02 PM
bbrock   Careful... those things can melt steel. :welder:   Sep 2 2018, 07:18 PM
gereed75   Got a 110V Hobart Handler back in the spring. It ...   Sep 2 2018, 08:42 PM
Jamie   Got a 110V Hobart Handler back in the spring. It...   Sep 3 2018, 09:25 AM
IronHillRestorations   Make 3 or four 1" beads on some 1/4" ang...   Sep 3 2018, 08:18 AM
mb911   I wonder if I should do some welding youtube video...   Sep 3 2018, 12:21 PM
mepstein   I wonder if I should do some welding youtube vide...   Sep 3 2018, 12:42 PM
mb911   I wonder if I should do some welding youtube vid...   Sep 3 2018, 02:15 PM
mgp4591   I wonder if I should do some welding youtube vid...   Sep 3 2018, 02:51 PM
mb911   [quote name='mepstein' post='2645105' date='Sep 3...   Sep 3 2018, 04:03 PM
mepstein   [quote name='mepstein' post='2645105' date='Sep ...   Sep 3 2018, 04:43 PM
mb911   [quote name='mb911' post='2645144' date='Sep 3 20...   Sep 3 2018, 05:08 PM
mepstein   [quote name='mb911' post='2645144' date='Sep 3 2...   Sep 3 2018, 05:53 PM
IronHillRestorations   I wonder if I should do some welding youtube vide...   Sep 3 2018, 01:47 PM
mb911   I wonder if I should do some welding youtube vid...   Sep 3 2018, 02:20 PM
gereed75   This is one of the best vids IMHO. https://m.youtu...   Sep 3 2018, 01:27 PM
Chris H.   This is a decent series: lzBGZaS1apw There are s...   Sep 3 2018, 03:45 PM
GaroldShaffer   If you have time heck with your local community co...   Sep 3 2018, 06:14 PM
saigon71   What can go wrong? :confused: :D Welcome...   Sep 4 2018, 05:37 AM
mepstein   What can go wrong? :confused: :D Welcom...   Sep 4 2018, 05:54 AM
falcor75   I had an old Esab 125A Miggy for most of my restor...   Sep 4 2018, 05:55 AM
76-914   Holding the tip at the correct distance and angle ...   Sep 4 2018, 08:35 AM
IronHillRestorations   I took a VoTech class so I could improve my TIG we...   Sep 4 2018, 10:36 AM
nihil44   Mepstein (I think your name is Mark - no discourte...   Sep 5 2018, 04:03 AM
eyecolor   Please have a fire extinguisher nearby. Don't ...   Sep 5 2018, 08:25 PM
mepstein   Please have a fire extinguisher nearby. Don't...   Sep 5 2018, 08:29 PM
davep   Some 40 years ago I took a night school course at ...   Sep 5 2018, 08:44 PM
r_towle   Get a sheet of 18 and 20 gauge. This is metal caul...   Sep 5 2018, 08:45 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:42 AM
