> rough running / non starting
JFG
post Sep 2 2018, 11:48 AM
The other day i drove my car for the first time, properly, and did a six or so mile loop just about.
The car started popping and losing power momentarily and i just made it back onto the driveway.
It was fine when cold but when it got hot the above started.
This morning i turned the key and it fired up straight away so i pulled it out of the garage for a check over.
I took the plugs out, they were slightly sooty and gaps are at 0.60mm on ngk bp6es iirc.
When it was back together the bloody thing would not start at all.
Lost my cool, nearly, and pushed it back in the garage.
Tonight i tested the coil and there is a good blue spark on the test plug. so i'm thinking the coil and electric ignition module in the distributor are fine.
My fuel pump is up under the tank and that is running no problems.
My next check is to see if fuel is getting to the carbs, i find it odd that despite the pump running and plenty of fuel the plugs were not flooded or even wet in any cylinder.
My first thought when it limped home was fuel evaporation but i'm not so sure now.
More checks to follow
(IMG:style_emoticons/default/headbang.gif)
jcambo7
post Sep 4 2018, 02:12 PM
Check fuel filters and your fuel tank strainer if you haven't yet. I and other members have had issues with electronic points modules. If you have points and can switch back to them you could truly eliminate that as the cause.
JFG   rough running / non starting   Sep 2 2018, 11:48 AM
jarodswordmaster   check your cylinder head temperature sensor. Mine ...   Sep 2 2018, 09:42 PM
JFG   i'm running twin 40idf on a 1.7 with an sv30 ...   Sep 2 2018, 11:27 PM
porschetub   No he has carbs,so that makes no difference,is the...   Sep 2 2018, 11:33 PM
SierraNevada   My crusty fuel lines clogged my webers up. Make s...   Sep 4 2018, 01:27 PM
JFG   only had 5 minutes spare today but have checked fu...   Sep 4 2018, 12:35 PM
jcambo7   Check your points gap also and makes sure it is ga...   Sep 4 2018, 01:25 PM
JFG   my carbs & entire fuel line system is brand ne...   Sep 4 2018, 02:07 PM
jcambo7   Check fuel filters and your fuel tank strainer if ...   Sep 4 2018, 02:12 PM
JFG   All plugs are firing fine on their respective lead...   Sep 5 2018, 11:32 AM
JFG   i fitted the new inline filter and flushed old pet...   Sep 7 2018, 10:18 AM
marksteinhilber   i fitted the new inline filter and flushed old pe...   Sep 7 2018, 11:42 AM
Mikey914   I recently had a similar issue I’ll share. Lost...   Sep 7 2018, 01:42 PM
JFG   The fuel lines have been checked and there are no ...   Sep 10 2018, 02:26 AM
BeemerSteve   If you are running points and condenser I'd ch...   Sep 10 2018, 09:20 AM
JFG   this is now frying my brain. fitted the new coil ...   Sep 10 2018, 09:39 AM
JFG   over the last 2 days i've gone through everyth...   Sep 12 2018, 12:33 PM
Localboy808   over the last 2 days i've gone through everyt...   Sep 17 2018, 09:57 PM
JFG   i had some time on it today. the tank is back on ...   Sep 18 2018, 06:55 AM
JFG   another look at the running and i've got idle ...   Sep 20 2018, 02:21 AM
BK911   A little late now, but for future issues... When I...   Sep 20 2018, 07:24 AM
- Lo-Fi Version Time is now: 18th March 2026 - 03:55 PM
