DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,828 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
alright so here is the back story- reinstalled the motorand transmission, didnt pay attenrtion to where the oil cooler was at the time, but it was on floor and not up under where it should be, so only choice was to disconnect the oil lines at the cooler, put the cooler back up where it was supposed to be mounted(it is now!) and then reconnect the lines - ok so that is where i am- and now i cant get the fitting tightened back down the last turn with out the line spinning with the fitting!!!! so it starts to twist and kink.
I have tried to hold it with my hand, and a pliers but i am afraid i will damage the line. SO what do i do?? its attached at the other end on the adapter plate and not accessible with out a huge amount of extra work. How much pressure is on this when the thermostat opens up and pushes oil thru the aux cooler? if this is not super tight ammi going to be blowing oil thru? and all over? its pretty tight, but should i loosen it up and put plumbers tape on the threads? if i hold the soft line with a pliers until the last quarter turn am i going to damage it? I am truely at the pint with this that if its complicated i dont have time and its not going to get done - and if it leaks its not either - i need a solution - if this is high pressure i will have to get it tight, if not then i can probably get by- Thanks Attached thumbnail(s) ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,819 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
The sealing surface is the flare inside the hose end, the threads only provide pressure on the two seating surfaces. It is OK to put some light oil or just a light dab of lithium grease on the threads so they don't seize or gall. I put some oil on the sealing surfaces too.
A tip Eric at BAT gave me is to get the fittings tight but loose enough where you can rotate the hose lightly to "lap" the sealing surfaces and continue slight rotation until tight. You don't want a kink or excessive twist in the hose at all. I've seen stainless braid hose that had an internal flaw that caused the inner reinforcement to constrict and totally close the hose. It looked like a camera shutter when I cut it open. |
Lo-Fi Version | Time is now: 3rd July 2025 - 03:04 AM |
