> Dellortos advice needed, Unable to adjust #2 cyl
Localboy808
post Sep 10 2018, 10:29 AM
This is my first set of Dellortos. Never even played with a set of Webers. I cant seem to adjust cylinder #2. Mixture screw can be turned in all the way and engine runs the same. If I pull the spark plug wire on #2 engine runs the same. If I pull any of the others engine runs worse. I changed the distributor and wires and did not help. Also checked my compression on all cylinders and they were even 115 - 120. These are new pistons and rings and havent run this enough to seat them yet. I'm guessing its fuel related. Is this a common problem with these carbs? My plan was pulling the jets out and blowing them out when I get home. Any carb experts willing to give some advice?
Thanks, Scott
GregAmy
post Sep 10 2018, 11:07 AM
Fouled idle jet will also cause a backfire/pop at idle in that cylinder. It's a common problem because the bypass air intake is at the "floor" of the carb and crap easily get in there.
Are these DRLAs? @914werke has some CB Performance Jet Doctors he's probably not going to use...
Localboy808   Dellortos advice needed   Sep 10 2018, 10:29 AM
rhodyguy   If the idle jet is fouled, Adj the idle air mixtur...   Sep 10 2018, 10:47 AM
GregAmy   Fouled idle jet will also cause a backfire/pop at ...   Sep 10 2018, 11:07 AM
Localboy808   Thank you guys. That was my plan when I got home f...   Sep 10 2018, 11:15 AM
GregAmy   Pull the idle jet and lightly blow air into it; wa...   Sep 10 2018, 11:36 AM
rhodyguy   Blow the air the opposite direction of fuel flow. ...   Sep 10 2018, 11:49 AM
Localboy808   well, got home. Pulled the idle jet and mixture sc...   Sep 10 2018, 09:31 PM
Localboy808   Also wanted to add. If I put my sync tool on cylin...   Sep 10 2018, 10:12 PM
ChrisFoley   Also wanted to add. If I put my sync tool on cyli...   Sep 11 2018, 06:35 AM
era vulgaris   Also wanted to add. If I put my sync tool on cyl...   Sep 11 2018, 01:05 PM
Localboy808   [quote name='ChrisFoley' post='2647695' date='Sep...   Sep 11 2018, 07:37 PM
cgnj   I tried turning the little air bleed screws befor...   Sep 12 2018, 11:55 AM
MarkV   I have Dellortos and I have had the same problem. ...   Sep 10 2018, 10:36 PM
rgalla9146   No mention of possible fouled spark plug ? eith...   Sep 11 2018, 05:11 AM
Localboy808   Good idea on the spark plug. I've had some fou...   Sep 11 2018, 12:17 PM
GregAmy   I've been looking for videos on these carbs an...   Sep 11 2018, 12:42 PM
cgnj   [quote name='ChrisFoley' post='2647695' date='Sep...   Sep 11 2018, 03:01 PM
Localboy808   Update. Replaced the plug on cylinder 2 and i can ...   Sep 11 2018, 07:35 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:31 PM
