> Dellortos advice needed, Unable to adjust #2 cyl
Localboy808
post Sep 10 2018, 10:29 AM
This is my first set of Dellortos. Never even played with a set of Webers. I cant seem to adjust cylinder #2. Mixture screw can be turned in all the way and engine runs the same. If I pull the spark plug wire on #2 engine runs the same. If I pull any of the others engine runs worse. I changed the distributor and wires and did not help. Also checked my compression on all cylinders and they were even 115 - 120. These are new pistons and rings and havent run this enough to seat them yet. I'm guessing its fuel related. Is this a common problem with these carbs? My plan was pulling the jets out and blowing them out when I get home. Any carb experts willing to give some advice?
Thanks, Scott
GregAmy
post Sep 10 2018, 11:36 AM
Pull the idle jet and lightly blow air into it; watch for any debris coming out of the small hole next to the jet (that's the air inlet port). Then pull the idle mixture screw and blow lightly through there as well.
The "jet doctor" plugs that small idle air hole with a lead shot ball and replaces the idle jet holder with a taller tube arrangement like the main jet uses.
Localboy808   Dellortos advice needed   Sep 10 2018, 10:29 AM
rhodyguy   If the idle jet is fouled, Adj the idle air mixtur...   Sep 10 2018, 10:47 AM
GregAmy   Fouled idle jet will also cause a backfire/pop at ...   Sep 10 2018, 11:07 AM
Localboy808   Thank you guys. That was my plan when I got home f...   Sep 10 2018, 11:15 AM
GregAmy   Pull the idle jet and lightly blow air into it; wa...   Sep 10 2018, 11:36 AM
rhodyguy   Blow the air the opposite direction of fuel flow. ...   Sep 10 2018, 11:49 AM
Localboy808   well, got home. Pulled the idle jet and mixture sc...   Sep 10 2018, 09:31 PM
Localboy808   Also wanted to add. If I put my sync tool on cylin...   Sep 10 2018, 10:12 PM
ChrisFoley   Also wanted to add. If I put my sync tool on cyli...   Sep 11 2018, 06:35 AM
era vulgaris   Also wanted to add. If I put my sync tool on cyl...   Sep 11 2018, 01:05 PM
Localboy808   [quote name='ChrisFoley' post='2647695' date='Sep...   Sep 11 2018, 07:37 PM
cgnj   I tried turning the little air bleed screws befor...   Sep 12 2018, 11:55 AM
MarkV   I have Dellortos and I have had the same problem. ...   Sep 10 2018, 10:36 PM
rgalla9146   No mention of possible fouled spark plug ? eith...   Sep 11 2018, 05:11 AM
Localboy808   Good idea on the spark plug. I've had some fou...   Sep 11 2018, 12:17 PM
GregAmy   I've been looking for videos on these carbs an...   Sep 11 2018, 12:42 PM
cgnj   [quote name='ChrisFoley' post='2647695' date='Sep...   Sep 11 2018, 03:01 PM
Localboy808   Update. Replaced the plug on cylinder 2 and i can ...   Sep 11 2018, 07:35 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:45 PM
