Diagnosing D-Jet Problem...solution & update, All of a sudden...loss of power... |
MikeInMunich |
Jul 6 2018, 08:13 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich gentlemen! (IMG:style_emoticons/default/bye1.gif)
It started with a thought and no wood to knock on, seriously! (IMG:style_emoticons/default/mad.gif) I was driving around Munich about 6 weeks ago and thought to myself, this car is running perfectly and needs nothing. What could go wrong? Then literally, less than a few minutes after that, it started. A light hesitation in the lower RPM range. Seemed like the car was choking a bit, or missing on once cylinder. I was at a D-Jet workshop last year with Dr. D-Jet. See https://oldtimer.tips/de/ Volker is a great guy and knows as much about this system as anybody. He tested the vacuum on my MPS last year and informed me that it was "borderline". So that was the main culprit. I took it out, sent it to him and this year it was indeed worse and thus the main culprit. Volker disassembled it and replaced the copper diaphram. Now it's tight like new. Some may be surprised that this is possible and / or where he got a new diaphram from. He had them manufactured or perhaps, I'm not sure, manufactured them himself. PM me if you want / need one and I'll send you his email address. So, with my restored MPS I hooked it up and, low and behold, the problem was quite the same, only about 10x worse! (IMG:style_emoticons/default/hissyfit.gif) Now, with the car immobile and Volker hundreds of km away, I'm practically on my own, with his and your advice, to try to track down the real problem. Volker thinks that because the MPS was operating sub-optimally previous to my purchase of the car that the mechanic or the P.O. had compensated elsewhere to get the car to run properly and that now that the MPS is sending a different signal to the CPU, things are off. More info: Just before the problem started my milage was really bad The CPU is the correct one for my MPS and working according to specs. Volker tested it. Engine has about 5,000 miles on it. Was rebuilt and running GREAT. Fuel pressure was set at 29 psi only about a year ago. I reckon it could have hardly changed on its own since then. (IMG:style_emoticons/default/idea.gif) The engine was originally a 1,7 but is now 2liters with a “proper FI performance Webcam” (as stated by the mech ic who rebuilt the engine) No adjustments were made to the FI to get it to run properly. It was running excellentwith a virtually perfect idle when warm and just slightly rough for the first 3 Miles or so. TPS plate and air temp sensor are new. What do y'all reckon could be the culprit? What should I be testing? I'm taking it to a place to tell them what to test, including: Fuel Pressure Plugs Compression CO value TPS setting Timing & dwell search for Vacuum leaks grounds Valve adjustment Fuel filter Relais Injectors... What else should I have them look for? Thanks for your input! With best regards from what was just ranked The Most Livable City in the World by Monocle Magazine, Mike in Munich |
MikeInMunich |
Sep 10 2018, 03:08 PM
I decided to take Volker‘s (Dr. D-Jet‘s) advice and change the injectors from the yellow (for 1.7 liter) to the green (for 2.0) from Bosch. Found a few at reasonable prices, used. Bought 6, 2 were defective.
Car is now running great. MPS is from 1.7 and was restored by Volker. It has a new diaphragm and holds vacuum tightly. CO value is at about 3.5% and my mileage on my first trip with girlfriend and luggage was about 18 MPG, which was pretty disappointing. Most of that was highway or at least in 5th gear. Thoughts? I think it’s running too rich and mileage should be about 40% better / closer to 25 MPG. For my European friends, that was 13 liters / 100 km (this is how we measure gas mileage over here). I purchased 4 MP sensors for 2.0 liter engines for about 60€ apiece. They all worked but gave higher CO values, one being as high as about 5%. Compression was 116 PSI on 3 cylinders and 123 on the other. Valves were adjusted, though they weren’t off by much a5 all. Timing checked / set at 25 degrees BTDC. Ignition is good. Cap and rotor in electronic distributor were changed. Fuel pressure is still at 29 psi / 2 bar. Next step, open up MPS and through trial and error adjust to get a lower CO value, goal being 2%. When successful, I hope my mileage is at least 30% better. Gas costs $6 a gallon over here! BTW. The CO value with the same MPS and the yellow injectors for the 1.7 was 0.5%. The car was running way too lean and quite badly, though I never did determine what was causing the ORIGINAL hesitation. Thoughts and feedback? Thanks! (IMG:style_emoticons/default/beerchug.gif) Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:48 AM |
