| Localboy808 |
Sep 10 2018, 10:29 AM
Member ![]() ![]() Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
This is my first set of Dellortos. Never even played with a set of Webers. I cant seem to adjust cylinder #2. Mixture screw can be turned in all the way and engine runs the same. If I pull the spark plug wire on #2 engine runs the same. If I pull any of the others engine runs worse. I changed the distributor and wires and did not help. Also checked my compression on all cylinders and they were even 115 - 120. These are new pistons and rings and havent run this enough to seat them yet. I'm guessing its fuel related. Is this a common problem with these carbs? My plan was pulling the jets out and blowing them out when I get home. Any carb experts willing to give some advice?
Thanks, Scott |
| Localboy808 |
Sep 10 2018, 09:31 PM
well, got home. Pulled the idle jet and mixture screw. Blew both out. Blew out the carb to where gas came out of the hole next to the jet. Car did run slightly better. Still cannot adjust the mixture screw. Turning it all the way in does nothing. If I pull the plug on the #2 cylinder the engine will stumble slightly now. I swapped the jet with the number 1 cylinder side of the carb. Same thing. So am I to assume the carb is still clogged inside somewhere?
Localboy808 Dellortos advice needed Sep 10 2018, 10:29 AM
rhodyguy If the idle jet is fouled, Adj the idle air mixtur... Sep 10 2018, 10:47 AM
GregAmy Fouled idle jet will also cause a backfire/pop at ... Sep 10 2018, 11:07 AM
Localboy808 Thank you guys. That was my plan when I got home f... Sep 10 2018, 11:15 AM
GregAmy Pull the idle jet and lightly blow air into it; wa... Sep 10 2018, 11:36 AM
rhodyguy Blow the air the opposite direction of fuel flow. ... Sep 10 2018, 11:49 AM
Localboy808 Also wanted to add. If I put my sync tool on cylin... Sep 10 2018, 10:12 PM
ChrisFoley
Also wanted to add. If I put my sync tool on cyli... Sep 11 2018, 06:35 AM
era vulgaris
Also wanted to add. If I put my sync tool on cyl... Sep 11 2018, 01:05 PM
Localboy808
[quote name='ChrisFoley' post='2647695' date='Sep... Sep 11 2018, 07:37 PM
cgnj
I tried turning the little air bleed screws befor... Sep 12 2018, 11:55 AM
MarkV I have Dellortos and I have had the same problem. ... Sep 10 2018, 10:36 PM
rgalla9146 No mention of possible fouled spark plug ?
eith... Sep 11 2018, 05:11 AM
Localboy808 Good idea on the spark plug. I've had some fou... Sep 11 2018, 12:17 PM
GregAmy I've been looking for videos on these carbs an... Sep 11 2018, 12:42 PM
cgnj
[quote name='ChrisFoley' post='2647695' date='Sep... Sep 11 2018, 03:01 PM
Localboy808 Update. Replaced the plug on cylinder 2 and i can ... Sep 11 2018, 07:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:30 PM |
