Early 914 brake light switch |
isdyl |
Sep 11 2018, 02:08 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi, I'm have a difficult time obtaining a brake two pole brake light switch for my 914 here in the uk. It is a Bosch 0343102008 as seen in the photo with the mechanical plunger. It screws into the side of the master cylinder. Bosch have no stock and I have just found one available at a Porsche dealer for £80 which I am reluctant to spend. Mine is leaking and I have tried epoxy to repair it but no luck. I was thinking that there must be pressure in the plunger area when in operation as it leaks and forced past the epoxy, so could I use another two pole pressure switch provided it has the correct thread? (12x1mm I think). Has anyone else replaced their plunger type switch with an alternative? The later cars use a single pole 0343102010 which works in a similar way but I think grounds through the switch body when the plunger is pressed rather than connecting the two poles.
Attached image(s) |
Tbrown4x4 |
Sep 11 2018, 04:53 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I don't think brake fluid should be coming out of the switch at all. There are seals on the "pistons" that actuate the switch when one circuit loses pressure. Maybe you are due for a new or rebuilt M/Cyl.
Lo-Fi Version | Time is now: 4th June 2024 - 07:17 AM |
