Early 914 brake light switch |
isdyl |
Sep 11 2018, 02:08 AM
Member Group: Members Posts: 113 Joined: 13-June 18 From: Woking, UK Member No.: 22,217 Region Association: England |
Hi, I'm have a difficult time obtaining a brake two pole brake light switch for my 914 here in the uk. It is a Bosch 0343102008 as seen in the photo with the mechanical plunger. It screws into the side of the master cylinder. Bosch have no stock and I have just found one available at a Porsche dealer for £80 which I am reluctant to spend. Mine is leaking and I have tried epoxy to repair it but no luck. I was thinking that there must be pressure in the plunger area when in operation as it leaks and forced past the epoxy, so could I use another two pole pressure switch provided it has the correct thread? (12x1mm I think). Has anyone else replaced their plunger type switch with an alternative? The later cars use a single pole 0343102010 which works in a similar way but I think grounds through the switch body when the plunger is pressed rather than connecting the two poles.
Attached image(s) |
isdyl |
Sep 11 2018, 11:51 AM
Ah yes! Brilliant - thanks - this forum is excellent. I have just dug around under the peddles and seen the other switch. You have saved me a load of bother trying to get that 2 pole switch.
I actually wrote to Bosch last week saying I couldn't locate a 2 pole version and could I use a 0343102010. They couldn't have been less helpful - I'm actually quite annoyed by their 'couldn't care less' replies! |
ClayPerrine |
Sep 11 2018, 02:55 PM
Life's been good to me so far..... Group: Admin Posts: 15,490 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Ah yes! Brilliant - thanks - this forum is excellent. I have just dug around under the peddles and seen the other switch. You have saved me a load of bother trying to get that 2 pole switch. I actually wrote to Bosch last week saying I couldn't locate a 2 pole version and could I use a 0343102010. They couldn't have been less helpful - I'm actually quite annoyed by their 'couldn't care less' replies! If you have to replace the switch, make sure the little arm is behind the big washer on the brake rod. The switch is held open by the brake rod, and closes with a spring when the brake is depressed. Also be careful of wire routing to the brake light switch. You can accidentally get it in the way of the accelerator bell crank. That will pull the wires off the switch. And the MOT won't like that. |
Lo-Fi Version | Time is now: 29th May 2024 - 06:00 AM |
