| Localboy808 |
Sep 10 2018, 10:29 AM
Member ![]() ![]() Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
This is my first set of Dellortos. Never even played with a set of Webers. I cant seem to adjust cylinder #2. Mixture screw can be turned in all the way and engine runs the same. If I pull the spark plug wire on #2 engine runs the same. If I pull any of the others engine runs worse. I changed the distributor and wires and did not help. Also checked my compression on all cylinders and they were even 115 - 120. These are new pistons and rings and havent run this enough to seat them yet. I'm guessing its fuel related. Is this a common problem with these carbs? My plan was pulling the jets out and blowing them out when I get home. Any carb experts willing to give some advice?
Thanks, Scott |
| Localboy808 |
Sep 10 2018, 10:12 PM
Also wanted to add. If I put my sync tool on cylinder 2 side of the carb, there is alot less vacuum or suction than on the Cylinder 1 side. Almost none at idle compared to the number 1 side. Not saying there isn't any. If I put my hand over it I can kill the motor. (IMG:style_emoticons/default/wink.gif) Just saying the reading is much less on the tool.
| ChrisFoley |
Sep 11 2018, 06:35 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Also wanted to add. If I put my sync tool on cylinder 2 side of the carb, there is alot less vacuum or suction than on the Cylinder 1 side. Almost none at idle compared to the number 1 side. Not saying there isn't any. If I put my hand over it I can kill the motor. (IMG:style_emoticons/default/wink.gif) Just saying the reading is much less on the tool. You need to balance the two throats on one carb by opening the idle air bleed screw of the throat with less flow until they match. The air bleed is the recessed (hidden) screw on the base iirc. |
| era vulgaris |
Sep 11 2018, 01:05 PM
J is for Genius ![]() ![]() ![]() Group: Members Posts: 986 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Also wanted to add. If I put my sync tool on cylinder 2 side of the carb, there is alot less vacuum or suction than on the Cylinder 1 side. Almost none at idle compared to the number 1 side. Not saying there isn't any. If I put my hand over it I can kill the motor. (IMG:style_emoticons/default/wink.gif) Just saying the reading is much less on the tool. You need to balance the two throats on one carb by opening the idle air bleed screw of the throat with less flow until they match. The air bleed is the recessed (hidden) screw on the base iirc. (IMG:style_emoticons/default/agree.gif) 100% I used to have DRLA40's on my old 2270. The two throats of each carb need to be balanced individually, and then the two carbs need to be balanced. Then connect the linkage and make sure the balance is still true. If the two throats of the same carb aren't balanced, you'll get the behavior you're describing on that carb. The air bleed screws are tiny little screws near the base of the carb, two per carb, hidden in a recess that you probably won't be able to see into. You'll need a tiny little flathead to adjust them. Be glad you got DRLA's and not Webers! Dells are fantastic carbs once you get them adjusted. I used to go 6 months or more without tuning them, and then when I'd go to check them they'd still be in sync. Very much set and forget. |
| Localboy808 |
Sep 11 2018, 07:37 PM
Also wanted to add. If I put my sync tool on cylinder 2 side of the carb, there is alot less vacuum or suction than on the Cylinder 1 side. Almost none at idle compared to the number 1 side. Not saying there isn't any. If I put my hand over it I can kill the motor. (IMG:style_emoticons/default/wink.gif) Just saying the reading is much less on the tool. You need to balance the two throats on one carb by opening the idle air bleed screw of the throat with less flow until they match. The air bleed is the recessed (hidden) screw on the base iirc. (IMG:style_emoticons/default/agree.gif) 100% I used to have DRLA40's on my old 2270. The two throats of each carb need to be balanced individually, and then the two carbs need to be balanced. Then connect the linkage and make sure the balance is still true. If the two throats of the same carb aren't balanced, you'll get the behavior you're describing on that carb. The air bleed screws are tiny little screws near the base of the carb, two per carb, hidden in a recess that you probably won't be able to see into. You'll need a tiny little flathead to adjust them. Be glad you got DRLA's and not Webers! Dells are fantastic carbs once you get them adjusted. I used to go 6 months or more without tuning them, and then when I'd go to check them they'd still be in sync. Very much set and forget. I tried turning the little air bleed screws before replacing the spark plug but I couldn't seem to get them to turn. Very tight! If I have the same problem when I get my new sync tool I'll give them another shot. Maybe I need to hit them with some PB blaster? Didn't remove them during the rebuild. |
| cgnj |
Sep 12 2018, 11:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 703 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
[/quote] I tried turning the little air bleed screws before replacing the spark plug but I couldn't seem to get them to turn. Very tight! If I have the same problem when I get my new sync tool I'll give them another shot. Maybe I need to hit them with some PB blaster? Didn't remove them during the rebuild. [/quote] That's not good. I have a 45 drla body that is has a single air bypass screw cranked so tight I can't loosen it. If any one has an answer for this, I can have a backup set. Carlos |
Localboy808 Dellortos advice needed Sep 10 2018, 10:29 AM
rhodyguy If the idle jet is fouled, Adj the idle air mixtur... Sep 10 2018, 10:47 AM
GregAmy Fouled idle jet will also cause a backfire/pop at ... Sep 10 2018, 11:07 AM
Localboy808 Thank you guys. That was my plan when I got home f... Sep 10 2018, 11:15 AM
GregAmy Pull the idle jet and lightly blow air into it; wa... Sep 10 2018, 11:36 AM
rhodyguy Blow the air the opposite direction of fuel flow. ... Sep 10 2018, 11:49 AM
Localboy808 well, got home. Pulled the idle jet and mixture sc... Sep 10 2018, 09:31 PM
MarkV I have Dellortos and I have had the same problem. ... Sep 10 2018, 10:36 PM
rgalla9146 No mention of possible fouled spark plug ?
eith... Sep 11 2018, 05:11 AM
Localboy808 Good idea on the spark plug. I've had some fou... Sep 11 2018, 12:17 PM
GregAmy I've been looking for videos on these carbs an... Sep 11 2018, 12:42 PM
cgnj
[quote name='ChrisFoley' post='2647695' date='Sep... Sep 11 2018, 03:01 PM
Localboy808 Update. Replaced the plug on cylinder 2 and i can ... Sep 11 2018, 07:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:30 PM |
